AEM EMS Get tuning help for your AEM EMS system.
Evo 8 ems
Old Jan 17, 2011 | 08:27 PM
Nismo2evoawd's Avatar
Evo 8 ems
Any one have syc issues when trying to start there car on aem ems, sometimes i dont but other times the car takes awhile to start.
Old Jan 17, 2011 | 08:29 PM
Even played with fuel trim so it wasnt to rich to lean ect. timing is prettyt much factory any ideas
Old Jan 18, 2011 | 07:11 AM
browningderek's Avatar
thats how the ems rolls on the 8. i tried everything to fix it including what it says on the aem forums. no dice. i bought a "trigger disc" from triggerdisc.com and put the settings in my ecu. starts up like a honda now! its only $100 but you gotta take the balance shafts out to run it.
Old Jan 18, 2011 | 07:26 AM
blackevolution8's Avatar
Thats a very common issue that has been tackled by several people. Doesnt seem to matter what settings you mess with, it will have long cranks still. Buschur has a crank disc which very well may be the same as what triggerdisc.com sells. It seems to be the only solution to slow down and/or stop the issue.
Old Jan 18, 2011 | 07:22 PM
DesignatedDiver's Avatar
I need to figure this out also.
Old Jan 19, 2011 | 11:58 AM
thanks guys i will look into that
Old Jan 19, 2011 | 06:57 PM
Chameleon@NLM's Avatar
is this the version 1 or newer version 2 your using? from what i hear the newer ems is alot better with the whole startup cranking delay. i have no personal experience with the newer ems yet. so just wanted you to clarify which one you were using.
Old Jan 19, 2011 | 07:05 PM
mrboost05's Avatar
i have heard nothing but good things as far as the sync goes on series 2 so i would guess its series 1 some of the tuners i have talked to say the trigger disc is not needed any more but every evo with series 1 has always had the long cranks.
Old Jan 20, 2011 | 03:22 AM
I have a series 2 and, normally I would be proud of this but, my crank is long unfortunately.
Old Jan 20, 2011 | 03:51 AM
infam0usndn2nv's Avatar
i got the aem ems series 2 as well i have the same thing going on with the start.. sooo dnt worry its normal
Old Jan 20, 2011 | 08:08 AM
16g-95gsx's Avatar
The issue is related to the trigger disks as others have mentioned. In an ideal world AEM wants a 12 tooth crank trigger wheel, and a 1 tooth cam trigger wheel. Therefore 24 teeth of the crank represents 1 engine cycle. The cam tooth would be considered a reference, so AEM would know to expect 24 crank teeth between each cam pulse, and therefore any more or less crank teeth would be considered an error. It then will define engine position, or timing, based on where it is in the tooth count with each new tooth counting as 30* crank degrees of additional rotation. The system calculates RPM based on the time or period between each new crank tooth, and you can log this value as "crank period". It then will infer timing degrees based on this value. The more teeth you have on your trigger wheel, the better the tendency for higher timing resolution in AEM, with AEM accepting a maximum of 24 total teeth per engine cycle (12 tooth trigger wheel).
Now, here's where your starting problem happens. Everytime you shut your engine down, the crank and cam will be at a different position, and the ECU must "Sync" itself with what is actually happening mechanically. For the factory ECU that is no problem as it only needs to recognize one type of trigger configuration and you'll likely notice that the factory trigger wheel is made in such a way that this can happen VERY quickly. However, AEM needs to be more universal, and therefore it needs to be able to recognize multiple types of user defined configurations. This is useful, but aso means that AEM must get a number of pulses and sometimes rotations before it an consider itself "sync'd". Hondas are great at firing up quickly because most of them come from the factory with a 12-1 tooth pattern already (and this is probably what AEM was catering to when they made 24 teeth the max allowable). Triggerdisk.com which is founded by a friend of mine, simply has replaced the factory trigger disks with that of the ideal AEM 12-1 pattern.
When you look at AEM, log "stat sync", and the moment that value goes to "ON" the car should fire up. If it doesn't, then you have a bit more to play with on your fuel and timing during startup. If it fires up immediately, then that is as good as you're going to get on your trigger wheel setup.
Hope that helps,
Ekoy
AEM EMS
Apr 21, 2009 07:17 PM
MREvolution
Automotosports - Illinois
Mar 14, 2006 08:11 PM
MrFairlady
Jan 16, 2006 08:55 AM
gonzstarr
AEM EMS
17
Jul 21, 2004 08:15 PM
chinalfr
AEM EMS
Jun 5, 2004 06:48 AM
