AEM EMS Get tuning help for your AEM EMS system.
AEM 30-6310 2003 EVO Wont Start
Old Oct 24, 2011 | 09:52 PM
DemiSlayer's Avatar
AEM 30-6310
Built Engine stroker with 272 cams
stock injectors stock turbo. 4 bar omni map sensor
Have loaded the stock evo 8 startup Cal.
Car will not start with the AEM i am getting a sync ok for the crank/cam sensor
The car will start and run on the stock ECU.
I have noticed that the fuel pump will come on when i press the throttle down a bit.
On the subarus and EVOs and series one box i install it and it fires up. Is there something i have missed with the new series 2 box ?
Old Oct 29, 2011 | 10:14 AM
n2oiroc's Avatar
The cal for the stock injectors was so lean my car wouldnt start. I bumped up the idc's at the start and idle cells and bumped up the cold start enrichment and it started.
Old Oct 31, 2011 | 08:09 AM
alpha's Avatar
Did you calibrate it for the 4 bar Omni map sensor? If not this has to be done
jasonharward
AEM EMS
Jun 30, 2017 07:18 AM
drupii
15
Mar 27, 2017 09:59 AM
rado
AEM EMS
Oct 17, 2016 08:29 PM
4ukc
Dec 26, 2015 12:18 PM
whiteEvo08Y
21
Dec 11, 2014 06:23 PM
