AEM EMS Get tuning help for your AEM EMS system.
Afert Market Know sensor Fo AEM EMS
Old Mar 23, 2013 | 07:53 AM
crisdiarata's Avatar
Hello Guys, any one knows whats the best Knock sensor to connected to the AEM EMS?? my oem sensor is broke i want to replace it with the best sensor, thanks.
Old Mar 26, 2013 | 11:12 AM
caLi4G63's Avatar
As far as I know, the stock one is the most commonly used. Just replace it with another OEM knock sensor and make sure to setup your knock sensor parameters in the EMS.
Old May 1, 2013 | 04:04 PM
Roberto774's Avatar
The knock link g4 could work like the oem sensor in the aem v2???
Old May 2, 2013 | 05:26 AM
What you mean with setup the know sensor parameters, sorry but im lost.
Serie 1
Old May 2, 2013 | 11:24 AM
Aby@MIL.SPEC's Avatar
I think the oem sensor is very good.
I know there are newer thru-bolt designed sensors; used on porsche / vw / audi = bosch sensor, but not sure if a boss on the block exist's on a desired location.
so just go with a new/used oem sensor.
Old May 2, 2013 | 12:17 PM
TheBoz's Avatar
Yep just use a brand new OEM sensor. You could switch to a Toyota style sensor, if you are on the Series 2 then you can tune the knock frequency, however if you don't know how to do that, I would just stick with the OEM sensor. It works just fine.
ExtremeDSM
10
Sep 1, 2012 06:38 PM
Mitchubishievo
10
Feb 7, 2011 07:03 AM
binh
Aug 15, 2010 07:08 AM
TomsEVO
AEM EMS
Jun 22, 2006 05:44 PM
SlowImport
AEM EMS
Nov 7, 2005 11:15 AM
