AEM EMS Get tuning help for your AEM EMS system.
Rough idle after 2 step
Old Mar 1, 2014 | 03:20 PM
alexui90's Avatar
every time i hit the 2 step on aem series 2 and then let the throttle off the car has a rough idle for few seconds and then cleans.. it pops some fires and i want to keep them...any ideas or theories ???
Old Mar 4, 2014 | 07:57 AM
Aby@MIL.SPEC's Avatar
i had similar issues.....my fix was to run less retard. this was on series 1.
1 thing to note, some of this stuff doesnt come up in a file compare....at least on series 1.
it has been years since i messed with them..so here is what i see / found.
main rev limit & 2step wizard: set to level 3... i think they are the same, but just confirm both are set the same.
for some reason, i beleive there is more, but i dont see anything within the compare....
also, if you use NLTS, no lift to shift, do your self a favor & reduce the base rpm limit settings to what your rev limiter is set to. if you have 12k in your nlts, then that will be your rev limiter during nlts. some people will say otherwise, howeever i have seen different.
do yourself a favor & make it the same. it's only a few key strokes!
oh, set your 2step to where peak torque is at.....4k is plenty high imo..... dont know how people get away with running higher...
Old Mar 5, 2014 | 05:08 AM
alexui90's Avatar
I ran 1 degree retard only.. I used all soft and full cut wizards.. I dont use NTLS... Thanks for the reply..
Dewar
Apr 17, 2013 11:21 AM
Evo_Matt
Feb 8, 2010 09:57 AM
fvaldes
Nov 1, 2009 07:44 AM
FOURCED
AEM EMS
16
Jul 29, 2009 07:22 AM
Deca Auto
Jan 16, 2008 02:58 AM
