AEM EMS Get tuning help for your AEM EMS system.
Setting up Wideband in AEM Series 2
Old May 17, 2014 | 01:46 PM
Teal2nnr's Avatar
I have a Zeitronix wideband that I want to hook up to my AEM S2. Can someone tell me how I would go about doing this? I know I can use one of the 0-5v pinouts (i believe) but as far as setting it up, I'm lost. I tried googling it, but I haven't found anything that would help me.....
Old Jun 2, 2014 | 04:11 PM
Teal2nnr's Avatar
Pin you analogue output (usually a white wire) into pin number 71 (which is the stock O2#1).
In your sensors tab, go to the O2 #1 chart and set your voltages. In the case of the Zeitronix you set 0 Volts = 9.6 AFR, 5.0 volts = 19.6 AFR and interpolate in between. Or use the formula AFR = 2*V + 9.6.
Old Jun 2, 2014 | 04:44 PM
Pirana's Avatar
Thanks for the info
Old Sep 4, 2014 | 02:10 PM
shangai's Avatar
How about with the 30-4100 gauge? How can I do it?
Old Sep 4, 2014 | 03:14 PM
doghouse's Avatar
Same for the bosch sensor?
Old Sep 19, 2014 | 12:28 AM
Teal2nnr's Avatar
Is it a Bosch LSU sensor?
http://www.zeitronix.com/Products/zt...ndoutput.shtml
This is what I used for my gauge. As long as you have a voltage chart, you're good to go. The ECU just needs to know how to interpret the signal its getting from that gauge.
Old Sep 19, 2014 | 12:31 AM
Teal2nnr's Avatar
There should be an 02 wizard for that....if you can't find the wizard then you can use this voltage chart.
http://aemelectronics.com/files/inst...GO%20Gauge.pdf
Old Sep 19, 2014 | 01:31 PM
shangai's Avatar
Mark all the Voltage map and increase or decrease the line till it match your uego to your ems reading! THAT'S ALL!!
sleeper04
Jun 7, 2015 05:57 PM
ch1215g
16
Feb 20, 2011 10:46 AM
wtf_is_a_evo
May 1, 2010 11:04 PM
RyuEvoIX
Aug 11, 2007 04:34 PM
hawaiian_evo
10
Jul 31, 2006 05:59 PM
