How to log boost using a Gauge with Datalogging (like AEM WIDEBAND)
SUSPECTED SCAMMER
Im trying to find out how im able ot log boost using the ecu so i can datalog it in evoscan. It has to be possible since you can do it with the AEM wideband. Im already logging with the wideband so the rear o2 sensor is being used. Can anyone point me in the right direction to setting this up
Thanks!
Thanks!
SUSPECTED SCAMMER
using the BOOST GAUGE and the Data wire that comes off of it, exactly the same way i used the wire coming off of the AEM WIDEBAND... thats how, i did search please dont tell me i didnt when i did. i couldnt find anything stating how to do what im asking.
SUSPECTED SCAMMER
thanks for your amazing help you sarcastic ****... i swear some people are just rude in general and they dont even know it, well ANYWAYS if someone with some knowledge can please help me that will be greatly appreciated
PM the answer to me if its easier Thanks everyone!
Ok I'm trying to understand what you want to do. Did you change the mdp sensor on the top of your intake manifold to something like a jdm 3-bar map or omni 4-bar map?
If you're trying to log directly from the gauge does it have a serial output lead or some type of analog output?
SUSPECTED SCAMMER
has a analog output just like the AEM gauge, i want to connect the wire from the gauge to a pin in the ECU thats not being used so i can log boost without have to spend money to go buy a mdp sensor
