AEM EMS Get tuning help for your AEM EMS system.
Little help AEM v1 from 1200cc to 2000cc inj.
Old Oct 30, 2014 | 09:10 AM
Pirana's Avatar
Question Little help AEM v1 from 1200cc to 2000cc inj.
I finally bit the bullet and finally upgrading to the ID2000cc injectors from PTE1200cc. Any ideas on how to start messing around with the tables? I would appreciate any help, thanks.
Vic
Old Oct 30, 2014 | 10:29 AM
TheBoz's Avatar
What table? You just need to adjust the battery offset table, and then adjust your fuel map. You might need to change your msec/bit also. But should be pretty easy. Then you will just need to adjust your start tables.
Old Oct 30, 2014 | 10:57 AM
tscompusa's Avatar
Its in your wizards. Go to Wizards > setup wizard and set the injector size it gets the latency pretty good as is and from there you are good. Otherwise you could just set them manually like Boz is saying.
Also what Boz said about the msec/bit is a good idea also to get your resolution down in the fuel map so your values dont max out prematurely.
Old Oct 30, 2014 | 11:56 AM
Pirana's Avatar
Thank you very much for the help. I will see how it goes this weekend.
Old Nov 1, 2014 | 09:38 PM
TheBoz's Avatar
That is a video for the Series 2 and 1100cc, but it is the same process.
Don't know if you are using AEM Pro or Tuner.
Old Nov 1, 2014 | 10:37 PM
wreckleford's Avatar
Changing the injector setting in the wizard only changes the latency values. You still need to change the values in the fuel map.
You have to right click the fuel table and go to change injectors/pressure and input the old and new injector sizes. You will then likely still need to do some tweaking to the map.
Old Nov 2, 2014 | 04:06 AM
tscompusa's Avatar
Yes I know. That's why I mentioned latency after I said it. Its right under the Wizards drop down menu
Old Nov 2, 2014 | 06:48 AM
I figure you know, but your response made it seem like all you would do is change the injector setting in the wizard and you should be good to go. Was just making sure the OP understood the full process.
Old Nov 2, 2014 | 02:14 PM
Lexus01IS's Avatar
Did you make the changes yet and how did it work for you?
Old Nov 6, 2014 | 01:58 PM
Aby@MIL.SPEC's Avatar
what fuel, mods & engine size.
I should have an old pte1200 cal file in my laptop.
pm me your email address if your still having issues
Old Nov 7, 2014 | 08:55 AM
Lexus01IS's Avatar
I need Cal file for ID2000's
Old Nov 19, 2014 | 12:28 PM
doh, damn that reading comprehension!
did you get sorted out yet?
Llew
Jun 8, 2017 04:16 AM
prockish_03evo
13
Aug 15, 2013 04:03 PM
N33d4sp33d
16
Feb 11, 2010 08:54 PM
Akirasoft
10
Apr 9, 2007 11:40 AM
