Kiggly 12-Tooth Trigger & AEM Infinity
Hi. I was wondering if anyone has experience running the Kiggly 12-Tooth Cam Trigger with AEM Infinity. A tuner said that they wouldn't tune Infinity without one, but when I did research on it I've only seen people with problems. If you could share any personal experience with it, that would be awesome!
Thinking more about this, I will probably shield the oem CAS and cam sensors wires when I work on my short block just to get cleaner signals to my ecu.
I will not use this because I have to be able to swap back to stock for smog. If I wasn't in CA, I would consider this and also run a shielded signal wire to ecu.
Im going to get the 12-tooth. When you suggest to run a shielded wire, would you still use the harness that comes with the Kiggly or rebuild it with shielded wire?
pharcydeabc
Sep 26, 2020 01:45 PM
