AEM EMS Get tuning help for your AEM EMS system.
A/F Ratio bouncing Rich to lean on decel
Old Mar 31, 2021 | 09:19 PM
EV1LIXEV0's Avatar
my A/F is bouncing from 10.5/11 to 16 on de-acceleration in gear which im assuming should be vacuum so ----?, have done a boost leak test and seems to be good. I also have random cut outs which feels as a fuel cut while cruising last a few seconds and during I can put my foot to the floor and nothing, push clutch in and release and power comes back. have an infinity, 2150CC, 6766, 2.2, DW320 fuel pump. I can go WOT to wastegate (25PSI) just fine. I'm lost
Old Apr 1, 2021 | 11:16 PM
MasterNater's Avatar
You're probably not falling under all of the necessary parameters for decel to activate reliably. Within the Infinity Tuner program, go to Wizards > Setup Wizard... On the left-hand side, expand the 'Advanced Setup' drop down, then click 'Accel and Decel Fuel'. On the right-hand side you'll find all the necessary options under 'Decel Fuel Cut'.
Old Apr 2, 2021 | 11:55 AM
EV1LIXEV0's Avatar
Ok ill check it out when I have time tonight, I only drive to certain places now because on the highway it can be scary being "random" loosing power but maybe if its not random and im tripping something I seem to not be able to replicate every time. I looked at my logs from infinity and I can see where my target is 14s and im at high 30s. voltage good, inj1 feedback good, oil pressure safety turned off so not tripping that, RPMs 3500s.
sometimes I let off and go to vacuum ---- and others I bounce back and forth until I get back on the throttle, speed up and let off the throttle again still in gear and will hit ---- like im trying to create a stronger vacuum
Old May 26, 2021 | 04:23 PM
EV1LIXEV0's Avatar
my injectors were turning off randomly from exhaust cam losing sync because the exhaust cam positioning sensor was bad.
DallasN2O
29
Jun 26, 2005 09:46 AM
zlancer
Lancer Troubleshooting
Jul 10, 2003 09:15 PM
