AEM EMS Get tuning help for your AEM EMS system.
AEM EMS with UEGO or with out ? Differance ? Q
Old Sep 14, 2004 | 12:20 AM
JDM-Spec.com's Avatar
Hi,
I am about to purchase an AEM EMS, there are two different kinds, one with UEGO and with out, $1,850 and $1,350. Can't I just buy a Wide Band O2 sensor for $80 and that would do it ? What is the UEGO option ? Please advise
My Evo
https://www.evolutionm.net/registry/...e.php?vid=2895
Old Sep 14, 2004 | 12:24 AM
gofaster87's Avatar
The Uego option is the EMS with a built in controller and it also comes with an O2 sensor. You cannot just plug an O2 sensor into the EMS without a controller. So to buy it seperately would be another 450 to 475 and it would be external(another box to install) instead of it being self contained within the EMS unit.
Old Sep 14, 2004 | 10:12 AM
Yes I inderstand, but what is defferent.... Does it self learn !!! ?
Old Sep 14, 2004 | 10:15 AM
feldguy's Avatar
I believe the EMS can self learn. You set target parameters for the EMS to follow (A/F targets) and it'll learn it. Nobody seems to talk about it much, though.
Old Sep 14, 2004 | 10:21 AM
Blak94GSX's Avatar
The 1313U model has the UEGO controller built-in. The only difference is that this locks you into not having a gauge that you can rely on. I recommend using the EMS with an external UEGO controller that has a nice calibrated display of its own that also feeds the EMS an input so the EMS gets the same data. This way you have a display to look at, as well as the EMS having O2 data for closed loop operation and logging.
www.zeitronix.com has a nice display type wideband. The AEM Gauge UEGO is nice too if you want a 52mm round gauge. The only problem with the AEM Gauge UEGO is that it only reads 11-17 AFR, which is sufficient but just barely.
Old Sep 14, 2004 | 10:23 AM
Blak94GSX's Avatar
The EMS has a feature called "Automap" which you can use to build a base fuel table. The EMS also has closed loop O2 feedback which can be used to adjust the fuel on the fly to hit a particular AFR target. Both have their uses, but need to be tuned and set up properly first.
Both features require a wideband O2 sensor, which can either be one of the built-in models (1313U), or an external type.
Old Sep 14, 2004 | 12:59 PM
GTVEVO's Avatar
So you can just feed the EMS with a 5v from any external unit and the auto tune software will still work correct? I am guess so it isn't a special plug to feed the 5v into the ems.
I have the PLX Wideband and I am debating the same question but I like the unit I have and they have their own gauges plus it has its own readout as well on the unit.
Thanks in advance.
Old Sep 14, 2004 | 01:01 PM
Blak94GSX's Avatar
It isn't as simple as hooking up a wideband and then driving around until the EMS tunes itself...
Yes, you can use any 0-5V wideband unit to feed the EMS a signal. There is a table in the EMS to set up the calibration for the type of wideband you are using.
Old Sep 14, 2004 | 01:04 PM
GTVEVO's Avatar
Right , that is understandable I just want to make sure that If I am going to spend the money that I can use all the options. Thanks for the info.
Old Sep 14, 2004 | 01:11 PM
Blak94GSX's Avatar
Yes I have seen several cars running the PLX wideband with the EMS. No Problem there, in fact the EMS has a configuration option to directly support the PLX M-Series.
Old Sep 14, 2004 | 01:13 PM
GTVEVO's Avatar
Perfect, Thanks again!
Old Sep 16, 2004 | 01:51 PM
mdzuricky77's Avatar
Doug and I used the autotune feature one day when we were bored and it does work. If done right it will build a conservative map, but nothing to keep. The best thing to do is find a good tuner and pay the money for the tune. It is worth it.
Old Sep 16, 2004 | 02:00 PM
VTECH8TR's Avatar
Nice info Black94gsx. The wideband o2 is on my list and you helped me narrow it down.
herrrta
AEM EMS
Oct 26, 2016 03:16 PM
boostawd16
Jul 3, 2015 09:09 AM
gr8stevo
Jun 16, 2014 07:38 AM
4g63evoeight
Mar 12, 2014 04:52 AM
Knyght
Jul 21, 2005 04:10 AM
