E85 Tune = +59 Hp & +97tq
Old Jan 5, 2009 | 07:11 PM
Creamo3's Avatar
I'll be documenting the various stages of tune on my setup running E70 & E85. I'm now up +121hp / +134tq over my previous pump 93 tune w/ the 50-trim. The current setup is pretty much maxed as I don't think I can squeeze much more out of the turbo/stock block. I have deleted older graphs in order to make room for the new ones. I will document the power production of my new build; I'm hoping the HTA3582 can push me over 650whp in DLL .
Current Mod list at the bottom.
Added 2/28/09:
32psi / E70 / 17 degrees up top (90% IDC / 2330Hz airflow) (+121hp / +134tq)
Latest tune v. Pump Tune
30 psi / E70 / 2 degrees more up top (+121hp / +114tq)
32psi / E70 / 15degrees up top (+88hp / +123tq)
New Setup (underway):
Shearer/BR HTA3582 Turbokit w/ .82_4-bolt hotside
Wiseco 1400HD Pistons (.20 over)
Howards Racing Connecting Rods
BR Stage 3 Head
GSC S2 Cams
A1 Technologies H11/L19 Headstuds
BR Dual In-tank Fuel Pumps
FIC 1450cc Injectors
Perrin Fuel Rail
APS BOV & Cat Back
Shearer V-Band DP / BR V-Band SD mid-muffler
ETS UICP
Nisei IC
HKS DLI2
Dejon Intake / AEM MAF adaptor / Amsoil EaAU6065 Air Filter
Hallman MBC
ACT 6-Puck w/ RRE Lightweight Flywheel
PPI Ported Intake Manifold & 65mm TB
Import DPS Intake Manifold Gasket
Ecuflash / E70_E85
Old 50-Trim Setup:
GSC 264/272
FIC 1150's
Walbro 255
RNR BB 50-Trim
APS BOV & TBE
ETS IC Pipes
Nisei IC
HKS DLI2
Ecuflash / E70_E85
Dejon Intake / AEM MAF adaptor / K&N Filter
Hallman MBC
ACT HD w/ Prostreet Flywheel
ARP Headstuds
Old Jan 5, 2009 | 07:15 PM
GotWheelHop's Avatar
Good numbers. You are one of the first 50 trim guys I have seen going past the usual 26-27 psi. Welcome to the corn crowd too.
Old Jan 6, 2009 | 01:10 PM
Creamo3's Avatar
I want to push this turbo as far as I can until I upgrade; it's great on pumpgas but loves the corn even more
Old Jan 6, 2009 | 01:14 PM
purevibez's Avatar
sounds about right
Old Feb 1, 2009 | 07:46 AM
Creamo3's Avatar
New Graph Added 2/1/09, more corn powa!!
Old Feb 1, 2009 | 11:08 AM
Creamo3's Avatar
2/1/09 - Last update for now on the graphs.
Old Feb 2, 2009 | 10:39 AM
8UpUrV8's Avatar
Nice! What's your Peak IDC so far on those 1150s? You said idc was around 80% at 422hp, what's it now with 500+?
Old Feb 2, 2009 | 10:46 AM
Creamo3's Avatar
The IDC's were around 80% at 450whp and now they are around 86% on a single Walbro at 500whp.
Old Feb 2, 2009 | 07:41 PM
8UpUrV8's Avatar
Sweet, so 1150's on the stock block and E85 match up pretty well eh?
Old Feb 2, 2009 | 07:47 PM
CWiLL's Avatar
welcome to the club im sure ull never switch back to pump gas
Old Feb 3, 2009 | 05:30 AM
Creamo3's Avatar
I would say so, I almost wish I would have gone w/ 1450cc injectors just to have some more headroom if I go a lot bigger down the road. I'm going to be doing a double pumper and probably a FP Red for the time being. If I can push that to 575-600whp in DLL I would be happy.
You've got that right, I can't wait until I get the good E85 and not the winter blend we have right now
Old Feb 3, 2009 | 05:36 AM
eve-slow's Avatar
Looks great bro! Not often do you hear about big # 50 trims.
You should stop by the shop in the spring. Would like to see how your monster runs.
-Dave
Old Feb 3, 2009 | 06:02 AM
lexat20's Avatar
Nice numbers. This makes me want to retune away from the 110 octane I've been blowing $$$ on. I dont think my 1000cc's would cut it though.
Why change to the Red?
Old Feb 3, 2009 | 06:55 AM
Creamo3's Avatar
Thanks Jeff. If you're still on the 3065 I would imagine that you would need a double pumper and probably 1250-1450cc injectors to run E85 at maximum power potential. The 50-trim flows ~50lb/min and I believe your turbo is around 60lb/min. I want to change to a Red to get both more power and better lowend. I'm still doing research to see what the max power potential is, but it looks like high 500 - low 600whp is attainable.
-Dave
Thanks Dave, I definitely need to stop by and chat it up. The Evo is going to need a nice detail after this winter. I was talking w/ your bro and we're going to try to hit Byron sometime this year.
Old Feb 5, 2009 | 06:32 PM
wizzo 8's Avatar
Cant wait to see what kind of numbers you will do when the pumps change from E70 to E85. Is there a certain date this happens or will you just monitor your tune to see when it changes due to the switch? Any problems starting in the cold? That seems to be the typical problem.
