evo 5 engine swap question!!
Old Nov 13, 2002 | 07:29 AM
strangezz's Avatar
you shud see the cars they can get in New Zealand....
Old Nov 13, 2002 | 03:26 PM
spider's Avatar
Now don't start that I hate the Kiwis for the cars they get
Old Nov 13, 2002 | 10:54 PM
GsR's Avatar
GsR
Old Jul 21, 2004 | 04:03 PM
nix's Avatar
nix
I run a 4wd 1800 GSR (CM5A). Just got ALL the parts to convert to Tommi Makinen Edition Evo 6. Plus a Jap Spec Evo 7 engine (with E6 GSR box). Running 1800 GSR rear diff with Torsen LSD. Adding Evo 6 RS diffs front and rear when I find them. Expensive? HELL YES!... but still cheaper than waiting forever for one to buy... and definately cheaper, with far better handling than Evo 7 or 8 GSRs.
Anyhow this is either the third or forth converted GSR over here. All the others are very competitive. Yup it will be a lot of work, but worth it in the long run for me.
If using an Evo engine in FWD shell, I STRONGLY suggest using an RS front diff unit WITH LSD to reduce torque steer.
Just my 2 cents.
Old Jul 23, 2004 | 12:51 PM
evo4two's Avatar
ive done the conversion to a cc lancer coupe and used the 4g15 gearbox but machined the flywheel and ran a custom race spec. cordia clutch, i have also seen sigma flywheels and H/D clutches used as well. Try this website it may help. www.vysor.com/SummitGTX/lancerproject_1.htm
i know that the evo5 engine is mounted on the opposite side but the info might help anyways.
Old Jul 23, 2004 | 02:47 PM
DriftRunSir's Avatar
damn i've been looking for that link for soooo long! thank you! its one of the most informative sites on this subject.
Old Aug 17, 2004 | 09:55 PM
NATHAN MCAULEY's Avatar
dam u guyz r unlucky
over here in new zealand there are heaps of converted mirages OSL developments have a road driven drag car pulling low numbers on the strip.
heres a site www.ratemyride.co.nz if you look under mitsubishi there is a coupe converted to an evo 5 motor. i cant remeber what name its under exactly its something like "evo mirage" i think. then u can try to contacted him some how i gess. good luck.
another workshop is speedtech they have heaps of modified evo's and stuff.
www.speedtech.co.nz
sorry to rub it in but ill just go and have a look at my 2 evo's and make sure there still there haha
Old Aug 18, 2004 | 03:39 AM
Sonic1's Avatar
Why dont you import the drive train from a 4WD mirage from Japan....Thats what Im doing!! Bolts straight in....then you can look at going 4wd turbo. Jap mirages come in 4wd with the 4g15 dohc motor.
Jaime
Old Aug 31, 2004 | 12:58 PM
evo4two's Avatar
the site that nathan is talking about might be www.evocoupe.net this site has alot of ppl who have done turbo and awd conversions there is also another us based site its www.mirageforums.net there both got more info then you'll need
PHILLY EVO
Sep 5, 2016 09:14 AM
awda5fk
Sep 19, 2015 08:59 AM
RevMoto
55
Oct 1, 2012 10:16 PM
marell31
21
Sep 14, 2012 06:29 AM
darkstarbd
Nov 18, 2011 10:26 AM
