Lancer Engines
Old Nov 16, 2003 | 07:04 PM
RalliArt1994's Avatar
Question Lancer Engines
After a bit of searching ive found some of the lancer engines (4G series) motors and their specs. Alot of ppl ask about power and so forth, hopefully this will help
4G61
Type: 1595 CC EFI DOHC 16- Valve 4-cyl
Power: 97kw@ 6500rpm
Torque: 144nm@ 5200rpm
Gearbox: FWD 5spd
4G61 Turbo
Power 108kw@ 6000rpm
Torque:206nm@ 2500rpm
Gearbox:FWD 5spd
4G92
Type: 1597 CC EFI DOHC 16- Valve 4 cyl
Power 108kw@ 7000rpm
Torque: 148nm@ 5500rpm
Gearbox: FWD 5spd & 4WD 4spd Auto
4G92 MIVEC (I WANT ONE SO BADLY)
Type: 1597 CC EFI DOHC 16- Valve 4 cyl With variable valve timing
Power: 131kw@ 7500rpm
Torque: 167nm@ 7000rpm
Gearbox: FWD 5spd
4G93 Turbo
Type: 1834 CC EFI DOHC 16- Valve 4 cyl Turbo
Power: 145kw@ 6000rpm
Torque: 270nm@3000rpm
Gearbox: 4WD 5spd
4G63
Type: 1997 CC EFI DOHC 16- Valve 4 cyl
Power: 104kw@ 6000rpm
Torque: 172nm@ 5000 rpm
Gearbox: FWD auto
4G63 Turbo
Power: 138KW@ 5500rpm (179kw@ 6000rpm 92 ZR-4 model)
Torque: 265nm@ 3000rpm (300nm @3500rpm 92 ZR-4 model)
Gearbox: 4WD 5spd and 4spd Auto (4WD 5spd 92 ZR-4 model)
Thats all the motors i could find for the lancers? any question drop me a email
Old Nov 17, 2003 | 04:36 AM
Sunder's Avatar
Re: Lancer Engines
Originally posted by RalliArt1994
4G63 Turbo
Isn't the 4G63Ts the engine in the Evo? What happened to 206Kw?
I know for a fact I'm putting down 150Kw at the wheels on a conservative dyno.
You sure that's right?
Old Nov 17, 2003 | 02:36 PM
ok the 4G63B Turbo has alot of different power outputs
LANCER EVO I = 185kw
LANCER EVO II III = 191KW
LANCER EVO IV = 198kw
LANCER EVO V on = 206kw
Hope that answers your question
