What's causing this?
Old Feb 1, 2004 | 09:44 PM
eze's Avatar
eze
Well I've had a problem pop up recently in my '93 CC GL, it's got the 1.5 carb 4G15. What happens is I'm just accelerating normally and it will just sputter and jerk the car back and forward (like bunnyhopping). I thought it might be the plugs so I changed those about 2 weeks ago, but it still happens.
The only thing I can think of is a problem with the fuel system. I *think* it might only happen when I get dirty fuel (I nearly ran the tank dry the other day and it's happened since then). Could that be the problem?
Any suggestions appreciated!
Old Feb 2, 2004 | 04:24 AM
Sonic1's Avatar
Try changing the fuel filter.....or getting the carby cleaned.
Jaime
Old Feb 2, 2004 | 06:52 AM
eze's Avatar
eze
I thought it might be the fuel filter, I bought a new one but the old one seemed really clean so i didn't bother swapping it over.
Carby seems like a probable cause, I have some carby cleaner so I might try that tomorrow.
Old Feb 3, 2004 | 11:22 PM
rexhunta's Avatar
IM HAVING THE SAME PROBLEM !!!
except on cold.. apparanlty after a while these carbs give in.. so i'm gunna see bout fitting something else onto it..
Pete
Old Feb 4, 2004 | 12:15 AM
eze's Avatar
eze
I was kind of hoping it wasn't a carby problem because they're a ***** to service, but I drive the car like I stole it daily, and wouldn't suprise me if the carb is packing it in.
What are my options about replace/servicing the carb? I don't have alot of money atm though
Old Feb 13, 2004 | 09:41 PM
import_speedzz's Avatar
yeah.. i think same too..
Old Feb 13, 2004 | 09:51 PM
RalliArt1994's Avatar
if your carbz is f**ked dont even bother reapairing it... just make an adaptor plate and fit on it an old XD falcon carby... more power and cheaper
Old Feb 24, 2004 | 04:24 AM
pubsquash's Avatar
hey yah i had the same probem, first i thought its the plug cables, then the carbi, then the fuel. Nup its your thermometer thats on your intake manifold (the pipes straight under the carbi). You should see two spark plug like thingies on the intake manifold with cables or tubes going to them. GET THEM REPLACED! I got fairly new ones from a wrecker engine (never used apparently) for 40 bucks, swapped them with mine and whoala problem fixed.
Old Feb 24, 2004 | 08:13 AM
eze's Avatar
eze
ahh sweet, I might try a few wreckers tomorrow and see if I can pick some up
Old Feb 24, 2004 | 08:27 PM
eze's Avatar
eze
hmm well I'm not sure what I'm looking for... is it the screw type things in this pic?
Old Feb 24, 2004 | 08:36 PM
pubsquash's Avatar
yep here:
Old Feb 25, 2004 | 09:14 PM
eze's Avatar
eze
how hard are they to work on! I got a set from the wreckers and swapped them over, but I don't think I screwed them down all the way, see how it goes anyway
Old Feb 25, 2004 | 10:58 PM
Odium2004's Avatar
Let us know how it goes.
What exactally do they do?
Old Feb 27, 2004 | 08:48 PM
pubsquash's Avatar
So Eze how did you go with the new parts, did they fix the problem?
Old Mar 5, 2004 | 02:46 AM
Odium2004's Avatar
-=Bump=-
I'm having a similar problem, did it work when you swapped them over Eze?
