Mitsubishi Evo VII JDM Immobiliser help
Old Jan 8, 2013 | 09:37 PM
damoevo8's Avatar
Hey guys sorry first post but have had a look around for an answer any help is appreciated,
Recently purchased an Evo 8 import, with the factory immobiliser system, just wanted some help as my spare key (without lock/unlock) has the immobiliser stick but it doesnt work hence the car doesnt start with the spare key only the main key, which is an issue as i want a back up if i lose the main key.
How can i go about fixing this issue with the immobiliser stick, where should i take the car? Also should i get another main key cut and programmed aswell as the plain key will trigger the alarm if i try and open car manually?
Any help would be great thanks,
Damo
Old Jan 8, 2013 | 09:46 PM
fastyouth1313's Avatar
You need two programmed keys to program another. If you have one working one that doesn't work, the dealer has to do it.
Or...
If you have a tactrix cable or know some one who does. You can disable the imobilizer. Then your car becomes easier to steal :/
Old Jan 8, 2013 | 11:00 PM
damoevo8's Avatar
I have one programmed working key with buttons the other is the spare with no buttons, i understand if i disable it, it will be easier to steal, but how can i go about getting the other immobiliser stick programmed as one works and one doesn't, the receiver is mounted just under the ignition and when i put the spare it nothing happens any ideas?
I assume i can get another programmed key with buttons from a Mitsubishi dealer or key cutting place that does remotes?
Old Jan 10, 2013 | 04:22 PM
droppinbottom's Avatar
I recently had the same issue but I was still in the states at the time. Back there I had to call a local locksmith out and he cut and programed another key. If I did not do that, I would of had to go to the dealership to have them make me another key.
It is my understanding that a chipped key made by say company "A" can only be programed by a program machine by company "A". In other words you may not be able to take just any chipped key to a dealership and have them program it as their programer may not be compatible with the chipped key.
TomEvoX
Australian Forum
Jun 22, 2015 01:21 AM
wowzers
Sep 23, 2014 09:54 PM
Blizzard25
Sep 7, 2014 04:27 PM
kubaolong
Sep 12, 2013 07:23 PM
spikelynn72
May 13, 2013 09:48 AM
