Lowering a CC
Old Feb 23, 2004 | 04:22 PM
RalliArt1994's Avatar
Lowering a CC
basically i wana know if i lower my lancer will it toe in toe out or do i have to get the toe in toe out kit??
do i need to lip the inner guard to lower it???
any1 know anything... it would help!
Old Feb 23, 2004 | 05:06 PM
rexhunta's Avatar
I didn't have to do anything.. just put my springs in, gotta wheel alignment and it all worked fine btw i lowered mine 60mm..
Old Feb 23, 2004 | 05:12 PM
yeah but i got 17 inch rimz... and it rubz now when i go fast over bumps
Old Feb 23, 2004 | 05:18 PM
rexhunta's Avatar
The only other thing is to get the guards lipped.. most places will do this for you..
Old Feb 23, 2004 | 08:51 PM
vespa's Avatar
wheels much be wrong offset.... i have 17's and mine is lowerd 2.5inch all round and no matter what happens wont rub....
Old Feb 23, 2004 | 11:29 PM
wrong offset?
they are 17x7
i wana do toe in toe out cause it looks ****en mad
does any1 know how to do it?
Old Feb 24, 2004 | 12:24 AM
rexhunta's Avatar
Originally posted by RalliArt1994
wrong offset?
they are 17x7
You sure it was the toe in ? or do you want camber ? (where the wheels are on an angle and only the inside of the wheel gets worn)
Old Feb 24, 2004 | 12:37 AM
i dunno... i thought it was called toe in toe out
the whole wheel gets worn apparently..
u can buy kits to do it to cars
Old Feb 24, 2004 | 01:22 AM
vespa's Avatar
i hope your not talking about negative camber??? if so you got alot of reading to do.... and yes offset... 17x7 means nothing about the off set. you should do a search non offset and you will c its actialy how far in the wheels are.... and often ppl buy second hand wheels that are the wrong offset and hence get all the rubbing....
Old Feb 24, 2004 | 01:44 AM
rexhunta's Avatar
Originally posted by vespa
iand yes offset... 17x7 means nothing about the off set. you should do a search non offset and you will c its actialy how far in the wheels are.... and often ppl buy second hand wheels that are the wrong offset and hence get all the rubbing....
RWD Offset won't fit on a FWD offset car, it's rubs the rims..
Where they brand new or 2nd hand rims ?
Old Feb 24, 2004 | 03:05 AM
EVE00V's Avatar
I have the exact same problem with my 17s. Has only just started happening after I got some new tyres about a month ago. Does this mean the rims on the back are meant to be on the front?? If so, shouldn't Bob Jane know this??
Old Feb 24, 2004 | 03:23 AM
mine are 2nd hand.. but they are for a lancer case they were on a lancer b4
