Ideas for polishing Manifold
Hi guys,
I have an intake manifold from an SR20 that I need to polish. Between the die grinder and the dremel, I can get almost everything polished, except for a small 2-3cm section around the curve of the manifold. I can't get either tool into there.
My thoughts were at first a sheet of wet and dry and a lot of effort by hand, but my fingers don't really reach all that well down there either, and the wet and dry grips better to the metal than it does my fingers, so I end up sanding my fingers instead.
Any ideas?
Thanks.
Any ideas?
Thanks.
I am guessing that you already have the intake taken off the car if so I would take it to a place that does sand blasting they will just use a very fine grain and that will polish it up very quickly for you and save the skin on your fingers
if it is still on the car then try a compound like mothers metal polish that will help with the wet and dry but other than that I would not know...
