Shifting... My Tacholess 1.5
My CE doesnt have a tacho atm, there are more important things to spend cas first
but it kills me not knowing what Rev's im doing, and when i should be changing,
I can take a ruff stab from the sound of the engine... but its not accurate.
so when should i shift?
1st......
2nd @ 40-45
3rd @ 75-80
:s
i have no idea
Also, anyone know how to minimise wheelspin, coz its a ***** for it.
1st......
2nd @ 40-45
3rd @ 75-80
:s
i have no idea
I had this problem with my Mirage which is the USA version of that Lancer Coupe. All I can tell you about the shifts is you probably will end up not shifting soon enough if you just listen to the engine. I used to do that and I am sure that I ran the car well beyond it's powerband.
As for the wheel spin, you probably should look into some "whiteline" bushings that stop the front from popping up under acceleration. If you can keep those front wheels planted longer you should get better grip. I believe the site is whiteline.com.
WADAD
WADAD
i have a CE with the 1.8l and flattening it to the redline i can get about 50-60 in first, about 100 in second and ive been to 140 in third but thats about max in those gears, its prolly a little to hard.
I had a 1.5L 4G15 engine.
Not sure about the speeds. As for the powerband, I was saying that although I thought the car was still pulling I am quite sure I was well out of the POWER range of the engine when I shifted.
I think a better estimate for shifts would probably be 35, 60 and 90. I haven't had that car for over 2 years now though.
WADAD
WADAD
Okay, here is a video of changing from 1st-2nd at 6500rpm, then 2nd to 3rd at 6500rpm, and then upto either 4-5000 rpm ( wihch is around 130 i think), thought i'd stop there, Redline for 3rd must be up around 150-160..
Enjoy..
(just right click and save as.)
http://www.we-todd-did-racing.com/we...ZmQzMXk1NDE%3D
Enjoy..
rexhunta, u seem to know ya car, man i suck at shifting, i suppose i just need to practise more...havent had the car for long let alone my license. i try to never shift at redline because im scared itll fark my car up lol. i shift about....1st/2nd - 20-30km, 2nd/3rd - 50-60km, 3rd/4th - over 70km. how often do u drive like u did in the vid rexhunter and has ur car had many engine problems etc. just like to know how much i could push mine without doing damage, btw its a 1.8L
I change like that every now and then, usually 2nd or 3rd day, or in a bad mood.
I have never ever had an engine problem ( touch wood), but my car is always checked and looked after by my housemate ( who is a mechanic)..
I've had my car since Jan 2001, and its been through a lot of places, and been stripped quite a few times, so i know a quite of bit of it as i'm always playing with it..
[edit] Okay, On a dyno ( heavily strapped), 3rd tops out at 145, and 4th at 190. 5th we did not try, as the poor car was trying its hardest..
Originally Posted by troygamble
Would mine have a limiter?
My fool injected 1.5 CE 97?
and whats the diff between the carbs and the fool injected?
why is the carbz so much better?
Carby - big metal peice and no computer/afm/electrics, runs on a carburhetter (sp?) to supply fuel.
Fuel injected - Computer, AFM, and lots of electrics.
Yours should run a limiter controlled by the computer. And the Carby is diffintely not better !! You can do a lot more to a fuel injected car for tuning and parts then to a Carby.. So be thankful !!
