mIVEC PERFORMANCE after engine modifications
Old Sep 5, 2004 | 11:19 PM
JunCam's Avatar
Guys need some advice from anyone.. Now I'm currently drive Lancer Mr 1st gen Mivec 4G92
Below are my mod's
port n plosih with metal gasket 1.5mm, 64mm T.B, Jun 5.4 flywheel,Jun camshaft 304 + Jun cam sprocket,e-manage for air flow & ignition adjustment,K&N air filter,exedy clutch plate,cc upgrade to 1.8 used of mivec pistons, straight pipe exhaust with 2.4 diameter.
tuning my car with e-manage on dyno run without the Jun type2 cam = 141 whp,
is that correct figure for mivec with above upgrade?
tuning my car with e-manage on dyno run with the Jun type2 cam = 154 whp,
while the mivec is kick in the graph drop probably around 7-10 hp and rapidly up to 8600rpm... why I'm getting drop while mivec is kick in with Jun cam?
I've set on mivec shift point at 5500 rpm at e-manage. so what should i do to make sure the graph doesn't drop while mivec is kick in?
Old Sep 13, 2004 | 08:28 PM
Miveccyborg's Avatar
you'll need to set the mivec really high (7000ish) do a dyno run the set it really low (4000ish) then with the 2 runs find the point where they cross and set the mivec point there.
Where did you get the cams from and how much were they.
Old Sep 17, 2004 | 12:12 AM
JunCam's Avatar
I did try with 7000 rpm for mivec activation point, but it still giving the same thing.. but I don't think 7000rpm will be good since the car was setup for the drag race, even at open as early 4500 rpm it still giving the same ****...
is there anything to do with ignition or airflow??? Ok from the e-manage perceptions I id retard the airflow and advance the timing.. from the dyno graph given.. while mivec is kick in fuel consumption getting reach as 12%++ (AFR) even I had retard it to possible values..
it's really messy up me since while the mivec kick in I feel like no boost from the mivec power...
actually Im from KL so I bought it from one of our performance shop.. cost me almost 5K + valve springs..
Nice to have JUN cam coz it giving u very good idle characteristic withou any power lost
Old Oct 25, 2004 | 01:04 AM
zoe's Avatar
zoe
juncam
do u know where i can find brand new or even used jun type-II camshafts for 4G92?
shops: only left the valve springs, the jun flywheels sold, cams sold.
awhit17
11
Feb 20, 2015 09:03 PM
Boostin Perform
Apr 30, 2014 10:08 AM
David Buschur
Jul 2, 2010 10:06 PM
autoplus
73
Dec 24, 2008 09:28 AM
DrivelineSales
159
Dec 4, 2008 04:20 PM
