Water injection install special
Originally Posted by AutoMotoSports
sorry guys been nuts at the shop. on monday I will post up the pics from the install packet. that should satisfy ya
Eric
Eric
Where are the pics man. I am curious as well on this kit.
I havent forgotten about you guys. it has been so nuts here. Our web guy micah is out of town till the 23rd so I have been doing my best to put something together.
Eric
Eric
Eric,
Have you guy's hooked up a mechanical pressure gauge to the system? What is the pressure in the line from the pump to the nozzle from initial turn on at say 14psi to 30psi in a 4th gear pull? I am trying to figure out if the system ramps up pressure based on boost like fuel pressure does since it is progressive, or if it is static pressure +/- a few pounds?
Thanks,
Chad
Thanks,
Chad
Bump for pics and answer to question below when you guy's get a chance.
Originally Posted by kcevo
Eric,
Thanks,
Chad
Thanks,
Chad
Originally Posted by Smogrunner
Between the Buschur and the AMS setup, which will be more Xede friendly when v.3 finally come out?
I'm not sure what failsafes the Buschur or AMS systems have. The Aquamist DDS2 could be added to either system to provide boost cut/map switching capabilities. It will constantly monitor water flow to ensure it is within a specific range. A couple hundred bucks isn't bad insurance compared to your motor puking it's guts up on the road or some track because you ran out of juice.
