Automotosports - Illinois Automotosports is a Chicago based tuner specializing in 4G63T performance. With an in-house fabrication facility and engineers on staff, they will be bringing you the best in Lancer Evolution parts.
AIM MXL Digital Dash Release
Old Jun 15, 2006 | 09:48 AM
AutoMotoSports's Avatar
The same equipment found in the AMS Time Attack Car!!!
Forget a bunch of expensive Gauges cluttering the car. Have it all viewable in one shot!!
Aim Digital Dash
The MXL race data acquisition is an excellent choice for race cars and street cars alike! The MXL Pista and Pro models are the same system used by world class GT cup cars and LeMans racers, however versatile enough to use in the mildest of street cars. We have currently been using the AiM Sports MXL Pista Digital dash in our Time Attack car and ran it for the entire One Lap of America event, we couldn’t be happier with the results.
This Digital Dash system not only displays all your vitals on one easy to view screen, but also logs them. Some of the finer points of this system are:
-1 AMP + 2 binder connectors
-Lap Times & Split Lap Times
-RPM - numerical and graphical display tach
-Max RPM stored for later recall
-Total Run Time
-Gear Position
-Total and partial odometer
-8 analog sensor inputs for temperature, pressure, lambda sond, potentiometers, etc.
-1 wheel speed input.
-128 kb of non-volatile memory.
-Brilliant blue display with backlight.
-6 fully configurable alarm LEDs.
-10 fully configurable shift LEDs.
-Requires 8-15V power from vehicle. Auto Power OFF feature.
Along with being able to input readings from the factory ecu AiM Sports now offers plug and play digital displays that work with AEM engine management systems. AiM Sports’ digital race data acquisition systems are now fully compatible with all AEM engine management systems via a serial RS-232 connection. To enable the integration, AEM users must have firmware version 1.19 or higher. The plug and play simplifies installation of the MXL system as users need only install one harness between the MXL and the AEM ECU unit.
Once connected the MXL displays (and can record, depending on the model):
-RPM, boost (engine load / MAP)
-throttle position (TPS)
-air and water temperatures
-battery voltage
-speed
-gear
-2 lambda (fuel/air ratio) channels and 2 error channels.
-By using additional sensors (or tapping into existing ones) drivers can monitor other information via additional inputs on the MXL
View video of the Dash on our dyno here. REALLY cool stuff. Pay attention to the progressive shift light at the end.
http://media.ams-evo8.com/videos/amsmisc/aim.avi
we are also in the final stages of offering that mounting bracket viewed in the above video!!
Units range from $999 - $2299
View the Entire AiM Line on our site at http://www.amsperformance.com/store/...Path=22_46_223
Eric
Old Jun 15, 2006 | 04:47 PM
The video link was not working, it should be good now
Eric
Old Jun 28, 2006 | 04:10 PM
jbrown's Avatar
Eric
Still doesn't work for me. :-(
Old Jun 28, 2006 | 05:37 PM
LancerevoIX2006's Avatar
same here =[
Old Jun 28, 2006 | 05:38 PM
I will have mark get on it first thing in the morning. He has left for the day
Eric
Old Jul 5, 2006 | 12:37 PM
M5150's Avatar
Ttt
Old Jul 5, 2006 | 01:22 PM
shiv@vishnu's Avatar
We have the AIM Michron 4 dash on our shifter karts. It is good
-shiv
Old Jul 5, 2006 | 01:58 PM
speedomodel's Avatar
I wish now that I'd gone the MXL Pista route instead of with too many gauges. Nice product!
Old Jul 5, 2006 | 09:24 PM
jbrown's Avatar
YAY! The video works. Now I'm just pissed I spent $1,500 on Autometer Nexus Gauges :-(
By the way, is it just me? Or did I see 68.2 psi on that thing during the 3rd gear pull?!?!?!
Old Jul 5, 2006 | 11:21 PM
BlueDemon's Avatar
I think u were looking at the mph not the psi man i wish....
Old Jul 5, 2006 | 11:40 PM
housedj's Avatar
that's a nice unit but i like the MoTeC SDL better which fits nicely in the dash in place of the stock gauge cluster...
Old Jul 6, 2006 | 07:01 AM
kingkyle's Avatar
I'm very interested in this... I'll get some more info at the shootout.
-Kyle
Old Jul 6, 2006 | 07:05 AM
racerjon1's Avatar
Kyle,
We will have it on the Unlimited car at the shootout as well, so we can demonstrate, show you the track mapping, etc.
Jon
Old Jul 6, 2006 | 07:16 AM
scorke's Avatar
Kyle if your at any track in the NE for a hpde/pdx/SCCA regional event coming up shoot me a PM we run one of these on our race car, very neat.
Scorke
Old Jul 6, 2006 | 07:22 AM
jbrown's Avatar
Seriously dude, watch the video again. On the left side it says "Boost" right below the tach graph and directly under that you can see it reads way up there in the 60's when they get on it. One thing that seemed weird was I don't recall seeing it read vacuum when they let off, it didn't seem to go below 0psi.
