Automotosports - Illinois Automotosports is a Chicago based tuner specializing in 4G63T performance. With an in-house fabrication facility and engineers on staff, they will be bringing you the best in Lancer Evolution parts.
Headgasket woes....
Old Sep 12, 2007 | 10:14 AM
ExViTermini's Avatar
Headgasket woes....
I'm having a few issues with my headgasket. I was wondering which gasket you guys reccomend on a 2.3 with an o-ringed block?
Thanx!
Old Sep 12, 2007 | 10:19 AM
AutoMotoSports's Avatar
stock stock and stock. our drag car and time attack car both run stock gaskets.
How is your block O-ringed? what wire (composistion and size)
Old Sep 12, 2007 | 10:54 AM
AMS's Avatar
AMS
The gasket might not be the issue. What headgasket do you have now? how many miles on the setup and do you still run what you have in your sig, the 93oct tune at 560whp?
Old Sep 12, 2007 | 11:18 AM
Buksh's Avatar
Stock
Old Sep 12, 2007 | 03:02 PM
Its copper wire o-ring, unsure on the size. Id guesstimate about 3-4k miles on the motor so far.
The 560whp was on 93 and an m15(SMC) jet with pure methanol.
Old Sep 12, 2007 | 03:13 PM
eh, with the introduction of methanol the strength of your head gasket might not be the problem.
Have you pulled your head off yet?
Eric
Old Sep 12, 2007 | 08:08 PM
Eric
No, I have not. I've decided to switch to pure fuels though regardless. Not b/c I'm worried about the meth and headgaskets, I just have this full blown fuel system going to waste.....and i like the smell of race fuel.
I'm trying to decide the gasket to go with so I can pull it off and reinstall everything, hoping for a few days downtime at most, though I don't drive the car daily.
Sounds like stock it is, with a fresh set of arp's this time, I stupidly reused the arp's for a 3rd time last time
Old Sep 13, 2007 | 07:27 AM
Im concerened with the diagnosis of the car. Are you sure that its the gasket? the only real way to know is by pulling the head off.
Taking off the meth is a good idea. I would really look at the pistons for signs of detonation. Also this is a stupid question but you are Re-Oringing the block every time you take the head off right, meaning replacing the O-ring?
Eric
Old Sep 13, 2007 | 09:43 AM
I'm about 98% that its the gasket. At idle after it warms up with the cap off the fluid will over flow from the radiator, and then a few bubbles come up. You refill the rad, and it starts all over, constant cycle.
Just for my information, what is it about the methanol that makes things worse, ie why is it good to remove it?
I was told that the o-rings could last a second time torque, so when I replaced the head(bad guides/valve seals) with this one, I did not re-o-ring it.
This time however, I am.
New o-rings, new studs, new gasket.
I have not removed the head yet, hope to in a few weeks, just have too much going on. I've replaced the plugs several times at different gaps, and eyed the plugs real well, but could not see any obvious to me signs of detonation.
Old Sep 13, 2007 | 11:04 AM
hks-evo's Avatar
good luck man
Old Sep 13, 2007 | 01:21 PM
honki24's Avatar
hope all goes well for ya bro. The Roanoke/blacksburg area is yours! I'm over in Suffolk now.
Viegasjuice
Mar 5, 2013 02:36 PM
Mauricio Evo IV
Nov 4, 2011 08:40 PM
evoyrrah
20
Mar 2, 2011 11:38 PM
Red_Evolution
14
Aug 19, 2008 03:59 PM
mikiblueeyes
Jul 5, 2006 09:31 PM
