AMS 2.3 Stroker Kit technical question.
All the parts are in and i'm in the middle of assembly. On the website it says to notch the block.
"You will have to slightly notch your 4G63 block when installing this stroker kit. These two contact points will become apparent after you install the rotating assembly and carefully turn the crankshaft. The pictures below show you where to make the modifications."
My rods aren't coming into contact with the block... It's tight but the instructions with the rods only call for .060 inches which is a little over 1.5 MM. If i did the grinding as much as you guys show in the pictures i would have 5+ mm. It's almost impossible to measure but it looks like i've got at lest 2 mm in there now...
I'm just trying to get a feel for wether or not this is still a requirement. (Has the casting changed sense the old days?) I've got a 2005 VIII with the manley rods.
Do you guys do the grinding to be on the safe side? If so i'll go ahead. I don't want to remove material from the block unless I really need to. It looks like there's about the same amount of clearance between my rod and block at the webbing as there is between the rod and the main cap girdle.
I talked with a friend and he suggested that there might be slight variations in the castings which seems possible. Maybe there is more than one casting as well. I visualize a row of maybe 5 blocks or something... I also see that you have an '03. I wonder how many '05 strokers there are...
We have seen a number of blocks come through here and not all of them were casted the same. Some had a lot of material where we ask you to notch it out and others had very little material. We recommend the notching because we dont know the condition of the block that the stroker kit is going into for the kits that we sell out right. Also having a little extra clearence is a good idea to ensure that the rod never encounters the block.
After further inspection i've got plenty of room but i'm goign to have to take a little material off where the #1 rod bolt is VERY close to the skirt right at the bottom where the oil pan bolts up.
I also had to bend my oil squirters a little. They were tapping the piston skirt.
That is correct with the squiters. When Tim is assembling the 2.3 strokers and the oil squirters are very close to the pistons he bends them slightly out of the way for clearence so that they do not hit.
whenever I assembled my AMS stroker kit the rods were coming in contact with the balance shafts and the block. I'm using the Eagle crankshaft though so maybe that's why
as far as the oil squirters I just bent them out of the way.
Here is a link for the pictures that we have for the block where it needs to be trimmed. It only needs to be trimmed on the sides. I hope this helps
http://www.amsperformance.com/store/...products_id=94
