Automotosports - Illinois Automotosports is a Chicago based tuner specializing in 4G63T performance. With an in-house fabrication facility and engineers on staff, they will be bringing you the best in Lancer Evolution parts.
can tune e85 on 1200cc injectors?
Old Nov 5, 2008 | 02:47 PM
Dr. SS's Avatar
hey guys called the shop to get tuned for E85. was told that 1200cc on stock ecu will be very diffcult to do.... is this true? did alot of research and went with br double pumper and pte 1200s to run e85..
Old Nov 5, 2008 | 02:53 PM
SuPeRNeT's Avatar
Been there done that... You can tune 1200 on stock ecu, especially when running
e85 because your scaling goes way down. Its a little more difficult when tuning for 91 but not that much.
Old Nov 5, 2008 | 03:27 PM
Chris@AMS's Avatar
It is possible.
As with any performance modication, there is always a compromise. I wouldn't expect the car to drive 100% stock, but I can make it drive very well.
Often the issues that people have with larger injectors on pump gas is during, idle, startup and very light load cruising conditions.
Drivability will suffer slightly. If this is ok with you, I would be happy to tune the setup to its full potential for you.
Old Nov 6, 2008 | 10:17 AM
Dr. SS's Avatar
Chris,
thanks for the reply, will hopefully be coming in tuesday, am finalizing it with Darius.
How bad is the cold weather start up? i am in northwest indiana with pretty much the same climate as west chicago.
Also, has gas city, etc, switched to the winter blend already? is this a concern if they switch blends after the tuning date?
Thanks for answering my concerns,
Asim.
Old Nov 6, 2008 | 02:11 PM
redevo58's Avatar
Winter blend has been in effect for a while. I know in illinois the best blend of e-85 is sold only during july and august. Its september 1st when the change to winter blend begins to occur. search for the 3 levels of e-85 to know for sure when the changes take effect in your state.
Old Nov 6, 2008 | 03:03 PM
Chris@AMS's Avatar
The start up should not be bad, when the car is idling high, it actually runs really good.
As long as the ambient air is warm enough for the E85 to atomize, the car should have no issues starting.
Old Nov 9, 2008 | 08:09 PM
Gsxtremedsm's Avatar
I did it with my old 03 on e85 stock ecu. The car ran fine. Go for it!
Old Nov 9, 2008 | 08:20 PM
slow/ass/rs's Avatar
i just got my car tuned on e85 with 1200's yesterday and she runs great as good as i did with 750's on pump
Old Nov 24, 2008 | 06:20 PM
prostcj's Avatar
I don't think this is true. I checked with the distributer to central Il at least and E85 is delivered May 15 through Oct 15. E75 Oct 15 through April 14 and E80 through May 14.
Old Nov 25, 2008 | 09:19 AM
derekste's Avatar
Originally Posted by Dr. SS
Chris,
Asim.
Did you ever get your tune? How did you do??? EDIT: see those numbers in your sig, very nice. How about a dynosheet? CBlack FTW.
got a link to your results?
FWIW, Chris tuned my 1000ccs on 93 and the car does great. Going to switch to E85 in the spring hopefully.
Old Nov 25, 2008 | 01:56 PM
Chris@AMS's Avatar
Dino chart
Glad everyone's car is still running great!
Old Nov 25, 2008 | 02:25 PM
dsm25psi's Avatar
I use 1200cc, it runs and drives like stock and no idle problems all on stock ecu.
needsboost
Oct 11, 2014 01:40 PM
kingkorea76
12
Sep 3, 2010 08:08 PM
ilikeppie
Oct 14, 2009 02:22 PM
myevo8urcar
E85 / Ethanol
27
Oct 6, 2009 11:06 PM
Evo H8
Dec 2, 2008 05:22 PM
