Automotosports - Illinois Automotosports is a Chicago based tuner specializing in 4G63T performance. With an in-house fabrication facility and engineers on staff, they will be bringing you the best in Lancer Evolution parts.
Another dumb ?
Old Sep 23, 2009 | 11:07 AM
mexigun's Avatar
Another dumb ?
I couldnt start my exhaust install until this coming weekend cuz it got delivered monday and when I opened the box I found a foot long piece of pipe that kinda looked like a very short test pipe. What is that? I have the dp, cat, mid pipe and canister and for the life of me i cant figure out what that is
Also, do I need an o2 sensor spacer if I have your high flow cat?? Sorry for the noob questions.
Old Sep 23, 2009 | 11:30 AM
davidvi's Avatar
I think it used only when you use the stock DP and Cat. it's an extension piece.
Old Sep 23, 2009 | 12:34 PM
Andrew@AMS's Avatar
The short section you are talking about is an adapter for the cat-back if it was being mated to a stock cat. If you purchased our entire turbo back system, then you will not be using this piece.
You can install the entire turbo back in the car and drive it around to see if the check engine light comes on. We have seen some cars need the spacer and some do not in order to keep the check engine light from coming on. Keep in mind that even though you have a cat on the car it might still throw the check engine light because it is a high flow cat allowing more air to pass through it than the stock cat does.
Old Sep 23, 2009 | 01:30 PM
mexigun's Avatar
Helpful as always! Thanks!
TxFAkuma
Jul 13, 2016 05:15 PM
patkelley
Oct 16, 2014 05:34 PM
Hotsht94
11
Dec 22, 2012 12:46 PM
evane
Aug 21, 2008 02:32 PM
RSGuy
Sep 14, 2004 12:44 PM
