how would i know if i have a catted down pipe????
Old Dec 21, 2012 | 05:09 PM
Hotsht94's Avatar
recently got an eve 8 with a cat less exhaust and to pass emissions i need a catted one but is there any way to tell if i have a catted down pipe ????? doesn't seem loud enough to be cat less
Old Dec 21, 2012 | 05:12 PM
ak47po's Avatar
You don't know what a catalytic converter looks like?There are no catted downpipes that i know of.
Old Dec 21, 2012 | 05:22 PM
golgo13's Avatar
EvoM Community Team
Veteran: Navy
Get under the car and look?
Take a picture and post it up and we can tell you what you've got under there.
Old Dec 21, 2012 | 06:09 PM
foxbat's Avatar
I've seen many catted downpipes, It would have a wide converter housing.
Old Dec 21, 2012 | 10:30 PM
Hotsht94's Avatar
will post pictures tomorrow morning a bit late to see anything!
Old Dec 21, 2012 | 10:43 PM
barneyb's Avatar
I'm guessing you've owned a Subaru.
Old Dec 21, 2012 | 10:53 PM
KevinA's Avatar
Does your downpipe look anything like this?
Old Dec 22, 2012 | 08:57 AM
Hotsht94's Avatar
my downpipe and upipe are stock if that heps
Hotsht94's Avatar
hahaha no but my brother has a sti though!
Old Dec 22, 2012 | 09:00 AM
Shortbus115's Avatar
I just went through the same thing. My downpipe was a cat delete so I had to buy a new downpipe and a high flow cat. I still haven't had it inspected but its just a visual so I should be ok.
Crawl under the car. If you see heat shields like the picture posted you have a cat (meow). If you don't then you need to see if you have a test pipe that can be replaced with a cat.
Also the cat didn't really quiet my exhaust down so I wouldn't base anything on that.
Old Dec 22, 2012 | 11:02 AM
sparky's Avatar
It is difficult enough as is to get any large diameter DP to fit past the TC. I can't even begin to visualize a catted DP. There are DP's that eliminate the cat altogether such as the DC "cat-delete" DP.
If you have one of these cat-delete DP's then you are gonna need a catalytic convertor and a shortie stock like DP to get the car legal for smog test. There are some DP's that have a flex section that could maybe be mistaken for a cat.
Like the other guys stated, get your car up on a lift and get underneath to look around. You may have to borrow a stock DP and cat just like the one pictured in Kevin's post, from another local just to pass the smog test.
Old Dec 22, 2012 | 12:46 PM
barneyb's Avatar
I thought so. My WRX came with a pre-catalytic converter, a front catalytic converter and a rear catalytic converter. At least that year (2004) the STI exhaust was the same.
MisUnderStood
27
Feb 4, 2017 09:04 AM
TxFAkuma
Jul 8, 2016 08:10 AM
rydogg008
Feb 10, 2015 01:44 PM
EVO VIII Chris
29
Oct 1, 2014 06:51 PM
eliminator 429
Mar 29, 2014 03:21 PM
