*AMS Product Release* AMS Mitsubishi Lancer Evolution X Fuel Pressure Regulator Kit
The AMS EVO X Fuel Pressure Regulator Kit is designed for anyone running an upgraded fuel pump and or fuel injectors. Whether you are running too rich and need to back off the fuel pressure or if you are running too lean on your current injectors and need to raise base fuel pressure, this is the system for you! A vibration resistant, liquid filled fuel pressure gauge is included allowing you to monitor your fuel pressure. Requires no cutting or modifications to your vehicle for easy installation and/or removal.
Features
- Raise, lower or monitor your fuel pressure
- No cutting or modifications needed for easy installation and/or removal
- Fuel Lab 1:1 Black fuel pressure regulator
- Liquid-filled fuel pressure gauge
- Return line to mate up to the factory steel line
- Line and fittings to bolt up to any stock or stock replacement fuel rail.
- Mounting plate
- All necessary hardware
- Detailed installation instructions available online
- -6 AN fittings
- 0-100 psi fuel gauge
- 2008 + Mitsubishi Lancer Evolution 10 (CZ4A)
Click here for information how to purchase this item.
boomn29
Jul 8, 2019 05:09 PM
APM Racing
Midwest Region
149
Jan 13, 2014 11:31 AM
maperformance
Jul 4, 2012 08:13 AM
