Automotosports - Illinois Automotosports is a Chicago based tuner specializing in 4G63T performance. With an in-house fabrication facility and engineers on staff, they will be bringing you the best in Lancer Evolution parts.
instructions for bushings???
Old Nov 6, 2010 | 07:01 PM
kim.ry's Avatar
hi, i bought your underhood bushings for 5sp, and unlike the 6sp, it doesnt come with the cotter pins? am i supposed to use the corroded old ones those were on there? and no instructions? i cant seem to find it on the forum here, even though there is a nice write up about your competitive brand. also a installation instruction for the light front cross member would be helpful for me. where can i find these infos?
Old Nov 7, 2010 | 01:55 AM
Pal215's Avatar
Who are you referring to ?
Old Nov 7, 2010 | 06:07 AM
kim.ry's Avatar
This thread is under ams section isn't it?
Old Nov 7, 2010 | 08:06 AM
MuslimEvoFreak's Avatar
Here is the how-to for these and i bought my own cotter pins from Ace Hardware....Good luck!
https://www.evolutionm.net/forums/ev...g-install.html
Old Nov 7, 2010 | 07:23 PM
Scottr126's Avatar
For installing the shifter bushings I usually just re-use the cotter pins. If they are really corroded you can get replacements at ACE or Menards as mentioned below. The hardest part is pushing out the old bushings from the shifter cable, the best way is to use a set of needle nose pliars and push them out as shown in the below picture.
For the front crossmember you just need to remove the factory one and replace it with the ams one. Remove the tie-bar if you have it one. Remove the three large bolts holding it underneath and remove the 14mm nut/bolt holding it to the transmission mount. Then install the ams crossmember, just remember to use the supplied spacers between the front bolts and the crossmember.
(Bushings pictured are from an EVO X)
Old Nov 8, 2010 | 09:53 AM
kim.ry's Avatar
scott, from the package, i see there are 4 aluminum bushings. am i supposed to use just 2 each? other 2 are spares?
Old Nov 8, 2010 | 11:44 AM
Scottr126's Avatar
Use 2 on each cable, one on the top and one on the bottom. There are no spares.
Old Nov 8, 2010 | 05:25 PM
kim.ry's Avatar
thanks got the shifter bushings done. also lightweight cross member was installed, and question:
that triangular part(where it seems like the motor mount is built-in) need no bushings? that just gets rid of the OEM motor mount?
Old Nov 8, 2010 | 05:34 PM
Scottr126's Avatar
You got it. It replaces the crossmember and motor mount. No bushing.
Old Nov 9, 2010 | 02:40 PM
kim.ry's Avatar
thanks for such a beutiful piece (lightweight cross member)
BoostNY
Dec 17, 2016 02:31 PM
LCS
Jan 19, 2016 05:23 AM
RedLanEVO
15
Mar 9, 2009 10:28 AM
Boosted20
Jun 22, 2008 03:59 PM
