The next wave of Powertrain settings and information has been unlocked. There may be an option to actually disable the Tire Sensor system check on start up. This maybe done via accessing the Tire Pressure Sensor ID Check (TPMS CAN BUS)
I am looking for anyone who lives in the Brampton Area who wants to meet up so I can see what has been unlocked with my scan tools.
Also access to the EVO X has been further unlocked. if anyone is free today please let me know... My lancer is in the shop getting my eye lids and Vortex Generator painted and installed.
Quote:
there is a tall list of crapOriginally Posted by mmartahus
What do you mean "enhanced powertrain options unlocked"??
example
A/C Compressor Relay
A/C Switch
Absolute Load Value
Accelerator Pedal Position Sensor - Main Accelerator Pedal Position Sensor - Sub Airflow Sensor
APP Sensor - Main APP Sensor - Sub Barometric Pressure Sensor
Brake Light Switch Calculated Load Value Closed Throttle Position Switch
Cranking Signal Crankshaft Position Sensor ECT Sensor
EGR Step Motor Engine Control Relay Engine Oil Pressure Switch
ETV Relay EVAP.Emission Purge SOL Duty Exhaust VVT Angle - Bank 1
Fan Duty Fuel Level Gauge Fuel Pump Relay
Fuel System Status - Bank 1 Fuel System Status - Bank 2 Fuel Tank Differential Pressure Sensor
Fuel Tank Temperature Sensor Ignition Switch Injectors
Intake Air Temperature Sensor ISC Learned Value - A/C OFF ISC Learned Value - A/C ON
Knock Retard Learned Knock Retard Long Term Fuel Trim - Bank 1
Long Term Fuel Trim - Bank 2 MAP Sensor Neutral Switch
Normally Closed Brake Switch Oil Control Valve - Bank 1 Oil Control Valve - Bank 2
Oxygen Sensor - Bank 1 Sensor 1 Oxygen Sensor - Bank 1 Sensor 2 Oxygen Sensor - Bank 1 Sensor 3
Oxygen Sensor - Bank 2 Sensor 2 Power Steering Pressure Power Supply Voltage
Radiator Fan Control Relay - High Radiator Fan Control Relay - Low Radiator Sensor Temperature 1
Radiator Sensor Temperature 2 Relative TP Sensor Short Term Fuel Trim - Bank 1
Short Term Fuel Trim - Bank 2 Spark Advance Starter Relay
Target EGR Target ETV Value Target Idle Speed
Throttle Actuator TP Sensor - Main TP Sensor - Main Learned Value
TP Sensor - Sub Variable Intake Solenoid Vehicle Speed
Quote:
lol it has to work first .. but i am trying, everyone was busy today, so i gotta wait till tomorrowOriginally Posted by razo
+1Evolving Member
Quote:
well if it does, your PM box is going to be loaded. lolOriginally Posted by evo_soul
i’m defiantly interested in something like this, but of course i’ll wait for the details.
(any idea if something like this could void any part of our warranty?)
no this isnt a reflash or anything. Its just an active setting accessed via the OBD II interface or other buses.Originally Posted by razo
well if it does, your PM box is going to be loaded. loli’m defiantly interested in something like this, but of course i’ll wait for the details.
nothing that can void your warranty.
Nice evo finally you can access more than before. I remember when we were at the pub and evo went into my ralliart and just went crazy with all the stuff lol.
Quote:
havent had time to test it. Importing Vortex generators for the Lancer and EVO X on friday, just got it. And going to sit down either tonight or early in the week to plan some photoshoot stuff with AJ. I will give you the update as soon as I get a chance to plug it in and test it. My car is getting alot done to it in the shop. HIDs are finally done Originally Posted by 1BADEVO8
bump for an update
