Daytime Running Lights (IX EVO)
Old Jan 5, 2010 | 11:26 PM
three29's Avatar
i dont have any advice to give you, but i just wanted to say congrats on your evo!
Old Jan 6, 2010 | 06:00 AM
bl8ant's Avatar
Thanks. A local shop charged me straight time for the wiring. $180 bucks.
Loving the car!
Old Jan 6, 2010 | 01:12 PM
007WRX's Avatar
Wow, I did mine for about 8 dollars.
Old Jan 7, 2010 | 06:26 AM
bl8ant's Avatar
Sounds about right considering you typically don't pay yourself for labor.
Old Jan 7, 2010 | 12:23 PM
vince126's Avatar
Should have just ran a wire from the foglight of the driver side's fog to the radio fuse in engine compartment lol.
Old Jan 7, 2010 | 01:29 PM
ZeRoMaX's Avatar
What I did for my EVO was buy the daytime running light kit from Canadian Tire and ask the shop to install it for me. It was hooked up for my fogs to be my DRL.
Old Jan 8, 2010 | 06:08 AM
bl8ant's Avatar
Well at least now there is a thread with information that may be helpful to the next person searching the topic. Thanks for the responses.
Old Jan 20, 2010 | 01:02 PM
007WRX's Avatar
Hopefully this is a bit simplier:
1. Remove factory plugs from fog lights, move aside as they are not needed for now.
2. Remove fusebox cover and radio fuse. There is a small yellow box containing two small fuses. The one closer towards the fire wall is the radio fuse, this is the one you want.
3. On the passenger side fog light, connect one prong off the light (doesn't matter which one) to a ground, using a spade connector on the prong, and a circle connector around a bolt as a ground. On the other prong of the passenger side head light, hook a connector on there, and run a wire from that prong, to a prong on the drivers side light.
4. Once you have found the wiring diagram for the relay you picked up, connect one wire from the other prong on the drivers side light onto the correct prong on the relay.
5. Run the wire to the appropriate prong on the relay to the battery, 12v power.
6. Run a wire from the fuse in the fuse box, to the prong on the relay to trigger the relay.
7. Run a wire from the relay to a ground.
Try it out. It depends on what relay you buy but you'll be able to find a diagram online of which wires go to what.
I live in the Vancouver area, I'd be willing to do this for someone for a small fee or a case of beer.
I think the relay costed about 8 dollars, it was a 5 pin, the wire and connectors from Princess auto were only about 4 dollars.
Here is the outcome (I had the corner lamps on in this picture as well, yours will not be)
Old Jan 20, 2010 | 01:04 PM
shh!! sleeping's Avatar
I just leave my lights on all the time. When you shut the car off the headlights turn off... start the car they turn on...
Old Jan 20, 2010 | 01:05 PM
007WRX's Avatar
It's not the same as daytime running lights.
Old Jan 21, 2010 | 07:59 AM
Works for me...
Old Oct 31, 2011 | 08:59 PM
evojae's Avatar
Hi,I am new to this site and noticed your instructions for drls Im importing a 06 evo 9 mr to Vancouver and would like to do the same thing I was just wondering did you only have to ground the passenger side fog light or both ? I just want to have it work for inspection then remove it .
Thanks
Old Dec 10, 2011 | 03:37 PM
007WRX's Avatar
Just the one side.
Old Mar 26, 2012 | 06:34 AM
4warned's Avatar
Got my RIV inspection completed yesterday using these instructions - everything worked great...thanks for the how-to!!
Chris
Old Mar 28, 2012 | 05:18 PM
007WRX's Avatar
Good to hear!
