Help me...
Old Jun 2, 2004 | 06:18 AM
  #31
Danno's Avatar
Originally Posted by Dr Crash
you dont know Jeff or myself
your right I dont...whoopty do
Old Jun 2, 2004 | 10:18 AM
  #32
blaze_125's Avatar
I was watching a show last night, and they were changing the struts of a Toyota Echo. I read many, many "How to" but could never get it. After watching that show and actualy watching them changing the struts, it looks freakin easy.
Take off the brake line
Take off the 2 bolts at the bottom
Take off the 3 bolts on the tower
Take out the strut
Swap the spring
Do everything in reverse
I wish I saw that before
Old Jun 2, 2004 | 10:22 AM
  #33
jtc's Avatar
jtc
It really is that easy, just make sure you don't have any bolts left over at the end, and you should be good to go!
Old Jun 2, 2004 | 12:07 PM
  #34
Danno's Avatar
dont do that...jsut the one bolt in the center of the tower...you will see and figure it out
Old Jun 2, 2004 | 12:28 PM
  #35
sillypuddy's Avatar
if you are REALLY REALLY crazy.. i saw a guy who did it without a spring compressor
he use a bunch of zip ties around the coils and it held it long enough for himt o take it apart.. then all the zip ties broke off VERY shortly after..
-joe
Old Jun 2, 2004 | 12:31 PM
  #36
blaze_125's Avatar
Isn't that the one that holds down the spring?
Aren't those 3 bolts holding up the strut assembly?
Old Jun 2, 2004 | 12:32 PM
  #37
blaze_125's Avatar
If I do that, I might as well sit on it while taking off the screw
Old Jun 2, 2004 | 12:38 PM
  #38
jtc's Avatar
jtc
yes, the 3 bolts come off first, releasing the strut from the whole works, then while you've got it on the ground and the spring compressed, the top one comes off releasing the spring.
Old Jun 2, 2004 | 08:19 PM
  #39
Dr Crash's Avatar
yeah the best idea is to take out the 2 large bolts on the bottom and the 3 on the strut tower and remove the whole strut assembly, then clamp the springs and remove the top hat nut....as mentioned you could probably walk into a shop and ask someone to clamp the springs and pop the nut off for you, it'll only take 2 minutes...and yes it is as easy as it sounds
Old Jun 2, 2004 | 08:21 PM
  #40
cih's Avatar
cih
what about the 5th bolt ?
Old Jun 2, 2004 | 08:24 PM
  #41
deuxforever13's Avatar
whoa Doc. Crash, since when u are in Ontario?
Old Jun 3, 2004 | 09:24 AM
  #42
Danno's Avatar
really, i didnt do it like that. i left those on. put the compressor on before i took the strut out and then un did it. worked fine for me.
Old Jun 3, 2004 | 09:25 AM
  #43
Danno's Avatar
why make more work for yourself
Old Jun 3, 2004 | 09:38 AM
  #44
jtc's Avatar
jtc
well, it's easier to get the compressors on when the whole strut is on the ground instead of in the wheel well, isn't it? anyway, both steps are necessary, the order you do them in doesn't really matter.
Old Jun 5, 2004 | 10:21 AM
  #45
blaze_125's Avatar
My springs are on, and god does it even look tight. Installation took 4 hours with impact wrench and spring compressor. Installation was alot easier than expected. For anybody who wants to install springs... don't pay to get them installed. Make the mod your-self, unless you have no way to get access to spring compressor and/or impact wrench.
I'll you guys some pictures tomorrow...
