cobb ap and grimmsped ebcs question
i need some help, i just bought an cobb ap and the grimmspeed ebcs. i installed the ebcs and and my boost is spiking at 30 lbs. my question is will the cobb help with the spiking at all or do i need to have it tuned on a dyno.
2008 evo x cat back exhaust, stock intake with a cone filter
EvoM Community Team
Though this has been mentioned repeatedly....
STOP HITTING BOOST NOW unless you want a nice big cooling hole in your expensive 4B11. Wait until you get tuned or you WILL blow the car up.
I'm 99% sure that all of the ads I've seen for this BCS note to not install until you can get tuned. You are running way too much boost and your car has no way to correct it right now.
i dont im getting my car tuned but like i said its 10 hours away so im using the ots maps to get there safely i guess i could just hook the 3 port up when i get there its not hard lol
Simply un-plug the 3-port and you should be fine. It will have you boosting at waste gate pressures.
Edit: by un-plug, I mean the electrical connection. Leave the Vacuum hoses attached.
"The GrimmSpeed™ Mitsubishi EVO Boost Control Solenoid is designed to work with your factory computer (requires tuning)."
So.. yeah... just trying to understand how you would install a product designed to alter the boost... that you obviously knew would alter the boost considering that is what it is designed to do... and then just start mashing the pedal to the floor without taking the tuning into account....
Logic (and every single 3 port tuning guide around) would kind of dictate that you turn down the boost duty cycles BEFORE you drive the car to prevent motor molesting boost spikes like that.
