Running rich on Stage 2 OTS AMS 93 Oct
Is it safe to run a bit rich while on the map. I have all the setup needed for the map but instead of having a stock cat I have a test pipe. Currently I have.
List:
Custom Titanium Catback exhaust system
Ichiba Test Pipe
AMS Intake with Apexi air filter
Titanium UICP
Cobb: Stage 2 OTS AMS 93 Oct map.
I'm seeing 14.8 AF on idle which is ok.
12.8-14.2 on cruise
9.8-11 on full throttle.
When I let off after hitting high boost around 4-5k or higher I see the AF go near 9.2 for 1-2 sec before going straight to lean at 20.8. I backfire a lot. Also after the closed loop opens, goes from 20.8 straight to 12.4 then slowly lean out to 14.6 for idle.
People say I shoot a lot of black smoke when I get on it. Is this ok to drive as is? I been on this setup for a year and a half. I'm about to go in a custom tune down the road but I'm wondering if i did any damage to the engine running this rich?
List:
Ichiba Test Pipe
Titanium UICP
12.8-14.2 on cruise
Yes, a boost leak will cause you to run rich. Also, Stage 2 OTS maps are designed for a HFC, not the stock cat. Running a different air filter than the OTS map was designed for could also throw off your MAF readings, thereby affecting your AFR's. The AMS OTS map is designed with the K&N air filter that AMS supplies their intake kit with.
OTS maps are fine if you stick to that exact mod list, but when you start mix/matching and changing things up you really should get a custom protune.
Thanks for the response guys, I'm having someone do a compression test on Monday and make sure all is in line and he'll do a custom tune on it based off his car and work from there.
The problem is I change parts so much that I don't want to keep spending money to retune so I tried doing the OTS for a while. I'm finally coming down to a point where I'm actually happy with the parts on the car. I went through 3 intakes, on my 4th exhaust, 3rd UICP, went through 4 BOV but now back to stock BOV.
khaled_hourani
15
Apr 24, 2017 04:10 AM
turbotaloon95
29
Jul 12, 2016 07:42 AM
