First time Data Logs.
Old Jan 15, 2012 | 12:52 PM
just1n020's Avatar
So this is my first time with an AP. So far my first impressions are that I really like it. I have done alot of searching on this site to what to do and what to look for and it has helped a bunch. Anywho I have 3 logs from 2-2500 ruffly. From what I can tell my car took really well to the map I installed. On my knock sum I picked up 3 at about 5300 rpms but I am dismissing it cause it wasn't there on the other logs, but I am rather new to logging so any info or feed back you guys can give is very much appreciated.
I have an 08 GSR with a K&N drop in filter, resonated test pipe and that is all. I installed the stage 2 HKS DIF map and left the boost pill in. Also it very cold outside, around 20 degrees.
I would love to here some input.
File Type: zip
File Type: zip
File Type: zip
Old Jan 17, 2012 | 10:39 AM
just1n020's Avatar
Anyone? These were also done in 3rd gear. Forgot to add that in the first post.
Old Feb 29, 2012 | 06:42 AM
thiagobr03's Avatar
ugh injectors are going to hold you back, you are 100+ on them already.
