Stage 1 93 Octane on 2012 GSR
Old May 17, 2012 | 01:45 PM
3000GT-GTO's Avatar
Just installed stage 1 93 oct on my 2012 GSR, map notes says 24 or 23 peak, but I am hitting 26 PSI on third gear pull every time. I checked the log didn't find any knock higher than 3 mostly some 2s and 1s, was wondering if COBB have a 93 Low Waste Gate map for 2012 GSR over boosting.
For now I flashed to stage 1 91 Oct and Peak boost is now 24 PSI, checked log for knoc everything looks good no knock higher than 2.
Should I just keep using 91 Oct Map? or is there a 93 Oct Low waste gate map for 2012?
Old Jun 1, 2012 | 10:15 AM
blaze2682's Avatar
I didn't see one either but I think its safe to run 91 Oct just as long as your not peak boosting and your knock counts stay low.
Old Jun 1, 2012 | 06:48 PM
Black&Boostin's Avatar
In for answers. Im interested in a LWG map for my 2011 gsr. Im hitting 26-27psi, with minimal amounts of knock.
Old Jun 2, 2012 | 11:30 PM
3000GT-GTO's Avatar
Bakaunchi said 2011 and 2012 hitting 26 is normal, there isn't a low wastegate map for 2011 and 2012.
Old Jun 3, 2012 | 10:44 PM
3000GT-GTO's Avatar
I have now flashed to stage 1 91acn map, car is only boosting up to 20psi like target map says.
But this map is the only map, i dont get knock higher than 3 count.
I have been driving with stage 1 93 map for about a week, and i notice car would sometimes have knock sum of 6 to 7 on wot. I seriously think the boost is too high on 2011 and 2012 map,
Even the regular 91 map boost up to 25 up.
I only drove about 30 minutes with 91 map, and it has same problem with knock on wot,
If cobb can readjust map make it 23 24 psi, i think it would probaly solve my wot knock.
Old Jun 4, 2012 | 05:12 AM
manolo2011's Avatar
Can I install the COBB without any map at all and DO a base DATA LOG in order to compare stock vs STAGE 1 91 oct? Because when I tried to installed it, it tells me STAGE 0 bla bla bla. Does that stage 0 means STOCK?
Old Jun 4, 2012 | 11:46 AM
dldjros69's Avatar
Yes stage 0 means stock. Although it behaved oddly on my car. Then i flashed to stage 1 and everything was back to normal. I think they explain what stage 0 is on the tuner itself.
Old Jun 4, 2012 | 12:04 PM
jeffo24's Avatar
stage 0 is "cobb's version" of the stock ECU. Which is definitely not the same as the stock ECU. What it's there for boggles my mind
Old Jun 4, 2012 | 01:49 PM
3000GT-GTO's Avatar
You cant not do any log once it is uninstalled or unmarried,
I tried to do that and compare the REAL STOCK knock vs Stage 1 it doesn't allow you to do it.
Old Sep 15, 2012 | 08:36 AM
lavar56olb's Avatar
im running the stage 1 93 map on my 2012 gsr
upgrades are sf cobb intake and i peak at roughly 26
then tapering down. most knocks were 1,2 + 3 and nothing more
COBB said it should be roughly 1.5 over/under what the map gives and 27 is too high.
when i ran the stage 1 91 map i was peaking at 25
then tapering down. knocks were minimal i.e 1.....2...... or maybe 3 but usually 0
idk if that helps anyone but just fyi that whoever prolly isnt the only one. im waiting for a response from COBB, hopefully monday.
Old Sep 24, 2012 | 09:34 AM
cannyboy's Avatar
Same here - Stock 2012 GSR - was boosting to 26.7 on 93 Stage 1
Had to roll back to the 91 which is peaking at 23.4.
It's a pity, as the 93 felt real good. The 91 is meh...............
The Evo needs some new love from Cobb - If you have a stock car, hold off until they resolve these issues.
Old Nov 18, 2012 | 09:54 AM
blaze2682's Avatar
I am getting the same problem on stage 1 93oct. I have a CBE, UICP, Panel Filter, and Synapse DV. I was pushing 30psi. At first I thought it was the DV so went back to stock and even tried the stock air filter. Still overboosting I think it really is something with Cobb's map. I posted on the Cobb forum and did not get a reply. From what I have been reading 1-3 counts of knock is ok but, can't help but be safe with my investment. Waiting for a response from an e-tuner to see what they can do with it since Cobb hasn't responded.
Old Nov 18, 2012 | 04:17 PM
Drkramm's Avatar
Download access tuner race and lower wgdc
Old Nov 19, 2012 | 01:24 PM
blaze2682's Avatar
Just got a hold of Cobb finally. Need to do some 3rd gear pulls for them. Will keep you guys informed on whats going on stage 1 93 octane map and what Cobb says.
Old Nov 19, 2012 | 01:52 PM
RAI's Avatar
RAI
Get rid of it. You will hit fuel cut one day when it's extra chilly out, and that will make you **** your pants.
I have had to rebuild a spun a bearing before in my last car (3000GT VR4), so I'm extra sensitive to anything knock related.
