Can't clear P2096 code
After I had the spacer installed, I haven't had the code thrown since.
Does yours look as big as mine? I did the install in June so it's been roughly 10000kms and the light has never come back on yet. Could be blind luck, but it was coming on every 50kms when I just had a shorter spacer before. Here's the company that I got it from: http://www.gearheadsonline.ca/shop/p...&cat=51&page=1
I run 2 spark plug anti foulers and the code pops every 2 months or so usually after heavy traffic driving/crawling. the ap only works sometimes so I pull the negative terminal for a minute and done
Posted from Evolutionm.net App for Android
I just wanted to update this for you guys.
I'm 160 miles CEL free as of today. I replaced every gasket on the exhaust and tried 2 different spacers. What it ended up being is the rear o2 sensor.
Someone sent me one to try and ta-da 160 miles so far no CEL. Hope this helps.
