Just want to make sure... Stage 2 AP question..
Old Oct 4, 2012 | 06:50 PM
subrwho's Avatar
Yes, I know this has been covered. But I just want to make sure I'm truly safe.. I read the stage 1 map has the moved set too aggressive. So like others I switched to the stage 2 map today.. I only registered 2 counts of knock at one point and the car felt great. Just want to make sure this is a safe route with just an injen intake and uicp and 91 octane. Thank you!
Old Oct 5, 2012 | 06:38 AM
Kracka's Avatar
If you have a Stage 1 setup, run a Stage 1 map.
Old Oct 5, 2012 | 09:15 AM
subrwho's Avatar
That's what I was doing.. But was told that the stage 1 mivec setting is too aggressive. And that I should run stage 2 even with stock exhaust..
Old Oct 5, 2012 | 08:30 PM
DocBoz's Avatar
you should run stg 2 lwg if your exhaust is stock to be safe. if you look at hollywoodx's guide to modding he even suggest's it.
Old Oct 6, 2012 | 12:31 PM
subrwho's Avatar
Ok. Sorry for the dumb question, but what is the difference between the lwg map and the normal wastegate map? Thank you
Old Oct 6, 2012 | 04:05 PM
ChipperEvo's Avatar
LWG maps usually run lower boost due to lower waste gate duty cycle from what I understand. As mentioned above, unless you are monitoring it constantly, run stage 1 if you are set up for stage 1. I've read those threads about running Stage 2 on stock parts but never had a problem running stage 1 before I got the parts for the stage 2 set up.
mrevo331
12
Oct 6, 2014 08:56 AM
Kidkuda35
Jan 23, 2014 11:05 AM
aggieEVO
Mar 30, 2013 09:03 AM
hamiltonj2w1
Feb 21, 2013 05:11 AM
crak
Dec 3, 2012 03:23 PM
