Cobb AP alter Evo mpg calculations
Old Apr 2, 2014 | 01:51 PM
dbreeze223's Avatar
I have tried to search and cannot find the right words to describe what i am asking.
When i reflash my ecu with the accessport, will my dash mpg calculator still be relevant or will it not be accurate. My understanding is that the calculations are based on miles traveled and fuel consumption so it seems that it should still be fine. But if it is based on throttle opening or something then the calculations may not be accurate.
Old Apr 3, 2014 | 07:01 AM
brandobaggins's Avatar
That's a great question. Will the new A/F ratios and other modifications to the maps render the MPG calculation inaccurate? You're right, it depends on what factors mitsu's mpg algorithm uses. IIRC the Accessport claims better MPGs, but whether or not the display is accurate is another question. I'm going to guess it will still be OK, because most cars today have enough sensors to monitor ACTUAL fuel usage, and not just theoretical based on the computer.
Old Apr 3, 2014 | 01:43 PM
COBB Tuning's Avatar
MPG calculations will be accurate regardless of tune, until you start changing hard parts like fuel injectors.
-Chris
Old Apr 3, 2014 | 02:11 PM
dbreeze223's Avatar
Thank you for the response and as seen from cobb they say it will not change which indicates the ecu monitors fuel usage
Old Apr 3, 2014 | 02:12 PM
dbreeze223's Avatar
-Chris
Thank you, just installed today after almost having a problem with my usb hub but i got lucky by trying another hub and it worked fine
tzais01
Outlander Sport
Feb 14, 2013 08:20 AM
user 629782012
Jan 12, 2012 12:42 PM
jcsbanks
Jul 21, 2010 11:29 PM
tephra
Jun 8, 2008 10:07 PM
Pro
Sep 18, 2007 06:33 PM
