Cobb Stage 3 running lean?
Old Apr 29, 2014 | 01:40 PM
zer165's Avatar
I think my car may be running too lean but I'm not as experienced in this as most of you may be. Any help would be appreciated. Car feels great so far, just want to know if anything is wrong. I'm using 100 octane fuel and Cobb Stage 3 OTS map with correct MAF scaling applied and i live in Nevada. Weather has been mid 70s as of late. Mods are as follows: TurboXS Downpipe, TurboXS HFC (100 cell), ETS V2 Standard cat-back, AEM intake with Cobb turbo inlet tube, Cobb EBCS, ETS 4" FMIC. Spark plugs changed at 30k im at 40329 at the moment. 2008 GSR. I seem to get about 1 to 2 counts of knock around 3000 RPM. My AFR at WOT is 11.6~12.0
Old Apr 29, 2014 | 02:35 PM
alsong2002's Avatar
if you think you are running lean then change your relays, do a boost leak test and vacumm line for fuel pressure regulator under the plastic engine cover. i am running similar setup as you and i am running super lean with cobb map with the correct calibration. if you had check everything above then i think you will need a good tuner to dial in out for you. most of the time, lean issue is due to uncorrect calibration of intake.
Old May 14, 2014 | 02:22 PM
Ralli04Art's Avatar
are you running a 93octane map and using 100octane fuel?
Old Nov 1, 2015 | 08:22 PM
Maggio's Avatar
I have similar mods. Sorry to bring up an old post but I am having slightly lean conditions as well. 11.9-12.5 WOT. Anyone else here have a temporary remedy before pro-tune?
I thought cobb tunes were supposed to be more rich than lean?
3VOIXMR
Cobb AccessPORT
Sep 8, 2017 06:57 AM
Brokeassevo
Cobb AccessPORT
Jul 26, 2016 08:32 AM
Devon111
Feb 24, 2016 11:06 AM
TurboNubCake
Evo X Dyno Results
Feb 12, 2016 10:38 AM
MrDarkman430
Oct 24, 2015 11:23 AM
