innovate lc2 and ap
Old Nov 1, 2014 | 06:53 AM
dtmevox's Avatar
innovate lc2 and ap
so i installed my lc2 yesterday , it works great on the gauge but is off on the ap,
im using the aem w/b setting for the 0-5 volt input though the rear 02 like i should
but the gauge from the lc2 reads off from the ap ? i mean 0-to 5 volts is the same no matter whats sending it is my thoughts ? i dont have the rear 02 harness grounded at the same point as the w/b is that the issue ? if so what wire is it
Old Nov 5, 2014 | 12:45 PM
COBB Tuning's Avatar
Ground the orange wire to the same place as your gauge and that will lower the voltage input by a half volt and should then read correctly.
-Chris
Old Nov 30, 2014 | 09:47 AM
dtmevox's Avatar
chris , so i did the ground and it works great !,, but i get like 4 cels now , i knew the rear 02 delete would toss some codes but im getting a front 02 code as well ..any fixes?
Old Mar 29, 2015 | 05:07 PM
[Chance]'s Avatar
Any Luck?
Old Mar 30, 2015 | 08:36 AM
Originally Posted by [Chance]
Any Luck?
I believe we've helped the OP in an offline conversation. Are you experiencing similar issues with a wideband setup?
Marshall@COBB
Old Mar 30, 2015 | 11:38 AM
[Chance]'s Avatar
Marshall@COBB
No, not at all. I was looking into an LC-2, to use in conjunction with the AP logging features. I was curious if his problem had been corrected before I went ahead and purchased the LC-2.
D1andonlyantman
Oct 19, 2017 10:55 AM
mrm95
11
Sep 7, 2015 06:40 PM
yahh
Jan 16, 2011 08:01 PM
compscibOi
20
Jun 19, 2008 07:07 PM
GregGSC
15
Aug 20, 2005 01:16 PM
