Make your prediction
Old Mar 4, 2005 | 06:55 PM
Theibault's Avatar
13 even @ 101 What do I win if I'm right?
Old Mar 5, 2005 | 12:00 AM
tke_413's Avatar
Results
Ran 5 times, best of the night was a 12.713 @ 109.1
I know I could've hit a 12.6XX but they kicked me off the track when they thought the car was "leaking water out the front end." Actually I was next in line when they decided to run the sweeper tractor thing so as I was waiting I kept hitting my intercooler sprayer button. Guess I hit it too much, there was windshield washer fluid (instead of water) drenching the intercooler and dripping onto the track. Once they found out that I wasn't leaking anying I was told I could get back in line. Screw that, 5 passes on the stock clutch was enough for me. Almost a 12.6 without cams...I'm happy. I'll post up all the times and slips tomarrow, it's been a long day.
Old Mar 5, 2005 | 12:08 AM
imapunkclaimer's Avatar
nice job, are you gonna keep adding on to your car? maybe low 12's?
Old Mar 5, 2005 | 12:22 AM
j8's Avatar
j8
Nice job, I was right on the money...
Old Mar 5, 2005 | 06:13 AM
Smogrunner's Avatar
I OWN ALL! I guess 109, Tke 413 runs 109.1. Sorry to doubt your skills Tke, you obviously can drive pretty well.
Old Mar 5, 2005 | 09:25 AM
3000ways's Avatar
Wow great time
Old Mar 5, 2005 | 10:10 AM
tke_413's Avatar
Most of the cars were having troubles on the track and were complaining that they were ALL running at least .40 to .60 slower than usual. I don't think it had any effect on me. Here's my best 3 times of the night.
I'm positive if I could've ran that one more time and hooked up well in all the gears it could've ran in the 12.6's. Oh well I ended up taking the SUPERCHARGED MUSTANG TWICE, A WHITE STI, A BLUE STI, AND A RALLIART. As for the future, I'll probably take it easy and not hit the track again until the cams are installed in April. After that I suppose I should start looking at a clutch. Does anybody know what the fastest time is with the stock turbo, no alcohol injection, no EMS is?
Old Mar 5, 2005 | 10:12 AM
SterlingEvo's Avatar
Great times for the mods... I'd have guessed around 12.8 @ 107 too...
Old Mar 5, 2005 | 10:39 AM
EvoTio's Avatar
Those are some nice times. Were they on pump gas?
Old Mar 5, 2005 | 10:52 AM
tke_413's Avatar
No, I put 3 gallons of 110 in there at $6/gallon. Kinda funny, people complain about gas prices and then go out and drop $18 for 1/4 tank to burn up in a few hours.
Old Mar 5, 2005 | 10:57 AM
EvoTio's Avatar
Meant to say were you on pump gas, anyway congrats again on those times. I hope to be trapping about 108-110 MPH when I tune in my water injection on our crappy 91 octane.
Old Mar 5, 2005 | 11:03 AM
One more question... were those runs at 20psi? Or did you kick it up a bit with the race gas? You definitely ought to do lower IC pipe along with the cams
Old Mar 5, 2005 | 11:07 AM
tke_413's Avatar
The 12.8's were done at 22psi and then I tried to bump it up to 23. I went a little far and was popping the whole way down the track pushing 26psi when I did the 12.758. Then I turned it down a little and was going about 24psi when I ran the 12.713. It was still popping a little bit though so that's when I turned it down a little bit more and finally had it at 23 when they took me off the track for using my i/c sprayer too much while in line. I know if I would've ran with it at the 23psi and shifted like I had the rest of the night it would've put me in the 12.6's...but oh well.
Old Mar 5, 2005 | 02:01 PM
tke_413's Avatar
Time Slips
Here's all 5 runs. On the last one I missed 2nd gear completely, and the same on the 4th, but check out the MPH on the 4th!!
Old Mar 5, 2005 | 05:55 PM
3000ways's Avatar
Wow, looking at your time slips, it doesn't look like you ever really had a real clean run. Your cleanest run was the 12.713, but there is room for improvement. In all your other runs you trapped higher in 1/8th than your 12.713 slip. What happend in the third run, you were flying through the 1/8th, did you let off too early?
