Evo8 vs Lightly Mod'd STi - Video
Old Mar 22, 2005 | 06:41 AM
  #31
3000ways's Avatar
ct9a gsr that's great that you are running 12s, I added your name to the 12.00-12.99 list, please people if your EVO is running 12s and faster and your not on the list, let me know so that I can add you-
https://www.evolutionm.net/forums/sh...35#post1568735
Old Mar 22, 2005 | 06:46 AM
  #32
an0ther's Avatar
nice vid!!
Old Mar 22, 2005 | 06:51 AM
  #33
LA EVO 8's Avatar
Great Run, thanks for sharing...
Old Mar 22, 2005 | 06:57 AM
  #34
SterlingEvo's Avatar
Originally Posted by Vroompsh
the STI put his brakes on waaay to early....sucks for him
He's probably used to street racing, and braking when he knows it's over for him
Old Mar 22, 2005 | 07:07 AM
  #35
ct9a gsr's Avatar
One thing that still bothers me is that I've noticed I'm one of the slowest trapping Evo's for my ET. Almost every Evo I've seen and know that run in the mid 12's are all trapping much higher than me... in the 109mph's or higher. I don't understand why... I can never trap over 107 and barely even hit 107 as it is... but I run consistant times in the 12's... rawr!
Old Mar 22, 2005 | 07:32 AM
  #36
That is true... I was trapping 107 at 12.8:
Old Mar 22, 2005 | 07:36 AM
  #37
ct9a gsr's Avatar
Just curious, what specific rpm do most of you folks shift at in each gear specifically, on a stock turbo setup? If I can learn how to trap higher, maybe I can break into the 12.4's or 12.3's with my same setup.
Old Mar 22, 2005 | 07:49 AM
  #38
I guess I never really look where I'm shifting, I just go until it seems like it's ready Except for 1st gear, I think my natural tendency is to shift at around 7000 - this vid is roughly 1/8 mile:
http://www.streetracing-syndicate.c...aunch-80mph.WMV
Old Mar 22, 2005 | 09:02 AM
  #39
gsujeff55's Avatar
that just says that you are driving the hell out of it. i ran a 12.40@108.1. did that with a 1.70 60' time. if you have a better ET with a lower trap, thats a good thing.
also, it depends on where you stage. if you shallow stage(barely make the light come on) you will run better ETs with your trap but have worse R/T and better 60'.
if you deep stage(keep moving a little after light trips) then you will have higher ET with your trap.
some people just don't stage right, launch right and all that to have the best ET with thier trap.
Old Mar 22, 2005 | 09:54 AM
  #40
GottaGoFaster's Avatar
The reason for this is if you feather the throttle, your creating boost while standing still... the idea behind this is if you can generate boost right before you launch, you'll essentially be launching being already partially spooled... rather than holding revs and being in very low boost, or even vacuum. Special thanks to Giovanni aka IHATEPORSCHE for giving me great launching recommendations.
Want to tell me how you build boost while revving your engine at a stand still when boost is generated by load on the car?? I have a boost gauge and can sit there parked and rev my engine all day and build no boost. Only thing that changes is the vacuum
Old Mar 22, 2005 | 10:07 AM
  #41
twinevo's Avatar
i think he means increasing rpms to the desired range where boost comes on once you engage the clutch.
Old Mar 22, 2005 | 05:03 PM
  #42
4TUN8's Avatar
Start slipping the clutch, not enough to move, but slip it.
