1st time @ 1/8 mile after mods
Originally Posted by EvilDylan
thats strange that you arent getting faster times. I ran an 8.1 @ 85 with only a flash, mbc and muffler delete pipe.
the only other thing i can think of is maybe you are bogging off the line.
Originally Posted by vrrrm...psss
are all you guys on the stock clutch?
You might need a retune, but I don't know unless go dyno it again. You should be 20-40whp higher than your previous dyno...if for some reason, you're not, then maybe something is wrong.
You should really blow me away with cams installed...have you talked Al, and did you get reflashed after the cams?
no reflash after the cams.....I just installed them the other day....I guess Im about to pull the ecu and get an update flash
One variable is still unanswered, though. Your previous 9.2@74 was awfully slow. Whatever caused this to happen is likely causing your current problem. As an example, I ran a 9.0@81mph in stock form after a 2.44 60' and a missed 2-3 shift. Those mistakes caused a bad 1/8-mile time, but the mph was still there...
yeah you definitely need a retune. I was on stock clutch when i ran 90 mph in the 1/8th but that last pass killed the clutch and i am now running an ACT street disc.
Steve, have you gotten any runs in your current form?
Originally Posted by SterlingEvo
not yet man... let me know when you're going to the track. I was thinking about maybe going to Old Dominion (8th mile) in manassas next week. I think they have open runs on Wed. nights. I'm anxious to see what I can do now that I'm finally all tuned up
Also guys, from someone who drags in Al as well, it is HUMID AS CRAP down here w/ a lot of heat. Since this isa recent run I bet this is the cause of deviation in comparison to most everyone elses runs.
Huntsville actually gets snow, but I'm sure it still gets ***** hot in the summer.
Oh, I also have a vid if somebody will host it
