Help me analyze my 1/4...
I am having issues at the strip. I expect to be in the 12's with the mods I have, yet I can BARELY get into the 13's. Can someone please take a look at my times and give me some suggestions on how to improve? This was my third try, so I'm sure I'll get better with practice - but I'm too impatient.
These numbers are from this past Saturday at Speed World. I only made one run and it was at 12:30 am. it was about 100 degrees out. The heat wasn't an issue I think because there were some insanely fast cars running this weekend. (My favorite was the jet engine 6 second 252 mph run). I only got one run in because it way WAY too busy.
1.4 - Reaction (I wasn't ready)
2.0 - 60'
5.7
8.9 - 1/8 @ 78.2 mph
13.9 - 1/4 @ 98.1
2.0 - 60'
5.7
13.9 - 1/4 @ 98.1
well you can take about half a second off your 1/4 mile time with a 3 tenth better 60 foot. The trap speed is low too. What rpm are you shifting at?
with your mods minus the cams i was trapping 89 mph in the 1/8 and probably 110 + in the 1/4.
Well, something is definitely amiss. I know it's hotter than hell in Arizona right now, but still - I was expecting to get into the 12's. That trap speed is kind of a bummer. I shift between 7500 and 8000. Is that too high? Also, sometimes when I launch I torched the clutch, other times I get a smooth launch. I'm not sure why I'm so inconsistent.
2.0 - 60'
5.7
13.9 - 1/4 @ 98.1
2.0 - 60'
5.7
13.9 - 1/4 @ 98.1
Obviously, a decent 60' (1.7x) would drop you about a half second on the 1/4, but that doesn't explain your awful mph. Maybe you have a boost leak or your tune is awful...
I knew it was only a matter of time before Warrtalon jumped in. Thanks for the post.
I'm really at a loss why my time/speed is so shizzy. I had it tuned with 101 last week and then again the day before the race with 91. I was running about 96 octane (5 gallons of 101 and 2 gallons of 91) when I made that run a couple nights ago.
When I'm cruising around town, it feels like I'm getting a strong pull - especially after the cam install about two weeks ago. I might have a syncro problem with my shifter because it's hard to get it into 2nd and very hard to get it into 4th. 4th gear actually makes a rather loud and nasty grind noise too.
My tuner does nice work and has some other guys running their Evo's in 12/13's. Should I get it up on the dyno to possibly help diagnose any problems?
You forgot to mention you missed 2nd and 4th gear. By personally driving your car, it's definitely not a slouch! My two cents is you blow your wad b/4 the light turns green. Maybe try and stay as relaxed as possible and pretend you're on the road and not on a track. I know with my experience on the track I get very excited and the adrenaline starts pumping and it's hard to stay smooth and cool. I think if you were able to go to a track day and are actually able to do 5-10 runs in one night, you'll definitely see your times drop.
Perhaps you'll break down and finally get a short shifter?
Wow. I didn't realize missing a gear could take that much time off. I've got something going on with the syncros I think. My buddy picked up an 04 RS and that thing shifts so silky smooth. Mine is grinding like some kind of freak show!
Missing gears kills 1/4 mile times! If you factor in 2/10ths per missed shift, then 5/10ths for the 60' time, you have about a full second. There's your 12.9 in hot weather. The missed shifts also hurts trap speed, so don't worry about that either. Get that trans fixed and you'll be movin.
2.0 - 60'
5.7
13.9 - 1/4 @ 98.1
2.0 - 60'
5.7
13.9 - 1/4 @ 98.1
Man, missing gears takes a TON out of your time, I mean it totally kills your RPMs and momentum - which is essential in a turbo car! Like everyone said, practice is the key. Just don't practice on the streets
If I miss a gear, I just give up. Check it out:
http://www.streetracing-syndicate.co...nd%20Gear2.wmv
with your mods you ought to be well into 12's, even in hot weather. Good luck!
If I miss a gear, I just give up. Check it out:http://www.streetracing-syndicate.co...nd%20Gear2.wmv
And this 5.0 "missed a gear" (or slipped or something) and gave up against me:
http://www.streetracing-syndicate.co...tangGiveUp.WMV
Thanks for the comments. I took it to the dealership twice and they said there was nothing wrong with the gears. I then used the search feature on this forum board and found some stuff about syncros. I believe therein lies the problem. I put a call over to the local service manager and he said to bring it in and he'll go for a drive with me so he can see what it's doing.
