Finally 11.91@114.56
Originally Posted by whiteevo311
The boost controller is holding 19-20psi in first gear now as before it was only hitting roughly 16psi. I think its helping along with the 264s. I blurp the throttle and actually never look at my rpms while launching. Its all by ear. I roughly guess when I say 6500rpms, because I am pretty aggressive. My worst 60ft. in my last three track visits has been a 1.72 and that was with alot of tire spin. Otherwise all 1.6s. Today my act is being installed finally and we will see how that affects my style. I also just purchased some ra1's in 255-40-17 hoping that with the clutch will net some low 1.6s or even high 1.5s. That would be sick.
Thoughts?
Shep used to run the ra1 tires instead of drag radials a few years ago when he was going mid 9's. around 2002 I belive. At the time they were excelent for dragracing compared to the nitto 555 DR. I don't think the RA1 work as poorly as most autox R compound tires do.
but, I concur, doubtfull that they are significantly better than the stock advans.
But RA-1s are R-compounds. They are not drag radials and are not good for launching due to the stiffer sidewall. Are you using R-compounds on purpose? It's a great auto-x tire, but I don't think it will work better than Advans at the drag strip.
Thoughts?
Thoughts?
Thoughts?
Thoughts?
launching hard and I just get wheel-hop. They're just way to sticky!
Originally Posted by dr.mr
I agree, I run 255/40-17 ao32r Yoko's for auto-x and sometimes I'll try
Wheel hop would be bad. Anyone else tried R compounds and got wheel hop? Could the stiff sidewall contribute to the possiblity of wheel hop?
I autocross and hillclimb so these tires are great all around. They work very good at the track. Just lower the tire pressure. I plan on running 25f20r when I have the clutch installed.
weight transfers to the back when you launch. It dont really matter as much if the front spin. Also less drag while pushing the car down the track.
Who's the one cutting good 60fts. here, oh wait thats me. It works I dont know why.
The other variable here is the starting line at the tracks we are at. You might cut even better 60's by dropping your fronts down to around 24-25psi also, but I certainly wouldn't want to try to help you.
