So close yet so far away!!! 11.1 at 129 then bye bye front diff again!
Old Sep 7, 2005 | 09:34 AM
evoviiiyou's Avatar
Dave, get the quaife and get a 0 camber alignment. That would be enough for tens how you are driving her right now! Great traps for sure. Very impressive.
Old Sep 7, 2005 | 03:14 PM
rsr14's Avatar
Originally Posted by evodave
so if i put in a RS lsd i will have to mess with it? I was under the impression that it was bolt in
A RS diff is just like the quaife ( helical or torsen) and doesnt need any special maintainance.
Old Sep 7, 2005 | 03:20 PM
rsr14's Avatar
Originally Posted by Jasil
For all the Quaiffe bandwagon jumpers just remember if you ever track the car and lift a wheel the Quaiffe will become just like a open diff. That's why KAAZ or clutch type diffs are much more popular in road racing. Shep uses a KAAZ and so does Magnus.
If your sure your only going to drag the Quaiffe is fine.
A torsen sends power to the wheel with the MOST traction, thats why they work so well. If you did pick up an inside front wheel (highly unlikely on such a front heavy car) it should send all power to the the outside front. This is not necessarily the best thing because the outside wheel is trying to corner and accelerate at the same time so some understeer may result but not nearly as much as when an open diff smokes the inside front tire. Also a torsen goes open under deceleration which can help turn in.
Old Sep 7, 2005 | 04:07 PM
evodave's Avatar
From: driving the 10 second beast in ohio or running lightmods.net
nice info! looks like i may have a quaife lined up .
Old Sep 7, 2005 | 04:43 PM
spm1024's Avatar
Originally Posted by 4g63&gt
When have you ever seen a road racing car lift a front wheel? I think you have bigger things to worry about at that point.
stolen from the rre website
Old Sep 7, 2005 | 04:55 PM
sophic's Avatar
Lol!!!!
Old Sep 7, 2005 | 05:17 PM
4G63>OOOO's Avatar
Yeah, but Robi's sick and twisted. He don't count.
Old Sep 7, 2005 | 07:12 PM
smp3000's Avatar
It's all irrelevant though if Dave doesn't plan to do anything other than drag it....
Old Sep 7, 2005 | 07:27 PM
evodave's Avatar
def. not....actually i just want to run 10s with all the stock stuff on 94 octane then i am going to build it make more power then race it all over.....i want the car to do everything except autocross. run 10s on pump , trap over 135 on race , handle amazing , brake amazing and look amazing all while being reliable....it won't be hard. actually the car is setup more now for road racing then draging...
Old Sep 8, 2005 | 01:36 AM
nickracer9's Avatar
did you mess up the trans also? what happened?
Old Sep 8, 2005 | 06:21 AM
evodave's Avatar
nope....the trans is fine.
Old Sep 9, 2005 | 05:13 PM
DSMotorsport's Avatar
yeah, this is what I have to look forward to. Good luck dave.
Old Sep 9, 2005 | 05:30 PM
BYBYSTI's Avatar
call up jon @ TRE and get the drag gears would probably help alot
Old Sep 9, 2005 | 05:39 PM
gt40's Avatar
I won't speak about the kaaz but you are just wrong about the Quaiffe for road racing. It is nothing short of an unfair advantage. It made an amazing difference and there it just works.
Old Sep 9, 2005 | 06:27 PM
Jasil's Avatar
GT40......I'm not saying it doesn't work or it's a POS. My post clearly says that clutch types are more popular. Read this and come back to me.
http://www.magnusmotorsports.com/art...azvstorsen.htm
