1st Time I went to the Strip
Old Oct 30, 2005 | 07:53 PM
C6C6CH3vo's Avatar
First time I ever went down the strip (1/8 mile, 93 octane)
Oct 30 05:
1st run started great but it didn't go into 3rd gear until 2nd try:
1.829 60 ft
8.473
83.604
2nd run scratched 2nd
3rd run got tire spin again bad. I hit 4th before the end:
9.182 / 87.087 (I think the mph instrument at this track is off)
Spinning, car all over place:
8.826 / 86.32
I just couldn't get everything together for one run, but the next time I go I will have new tires - cause of the spin.
Dec 4 05:
Went to track again this time with new 245 45 17 tires which fixed most of the spinning but may have hurt acceleration (taller tire)
1st and only run (1/8 mi)
1.834 60 ft
8.319 ET
That was the only info they printed, no mph but I was about 7300 - 7400rpm.
I'm ordering a hotside tomorrow and I'll post the results in Feb (when track opens) to see how the hotside helps.
Feb 5 06:
10.5 HS installed
Again, 1st and only run (Just one run so I won't have to spend pwr mod $ on a clutch)
1.798 60 ft
8.045 ET
(mph said 88.739)
10.5 HS improved my time by 0.274 sec in 1/8 mi! (45 thousanths of a sec to go for the 7's).
I will test again this spring after I replace the stock catback and again after alcohol is installed and tuned.
Old Oct 30, 2005 | 07:56 PM
mac_05evo's Avatar
what are your mods???
Old Oct 30, 2005 | 08:01 PM
get faster's Avatar
Post 1/4 times, reaction times, and your mods (if any).
Old Oct 30, 2005 | 08:02 PM
Warrtalon's Avatar
Wrong forum.
Nice mph...it means you're making good power.
Warrtalon's Avatar
He said it was an 1/8th-mile track, and R/T is irrelevant.
Old Oct 30, 2005 | 08:47 PM
Jakeg97's Avatar
not bad for first time
Old Oct 31, 2005 | 05:23 AM
C6C6CH3vo's Avatar
93 octane
Reaction: 1.437 / I1: 1.829
Reaction: 1.178 / I1: 1.815
Reaction: 1.031 / I1: 2.367
Reaction: 0.832 / I1: 2.180
The tire spin made both the ET and I1 (I1 I think is 60') slower but strangely brought about faster traps.
Mods: 04 evo, GSC cams, Dynoflash, stock 9.8 turbo, stock catback, mbc, HKSrs.
Old Feb 6, 2006 | 11:22 AM
C6C6CH3vo's Avatar
10.5 Hotside helped my 1/8 mi time by 0.274 seconds. I even shifted in fourth at 7200 rpm 30 yrds before the trap and shifted somewhat conservative so I wouldnt miss.
See above thread for updates
Old Feb 7, 2006 | 09:32 AM
05WhiteEVO8's Avatar
If you are flashed you should be able to stay in third and cross the traps. I know I can anyway
Old Feb 7, 2006 | 09:35 AM
MuslimEvoFreak's Avatar
Good job man!!! I can't wait until I go to the track. It will be my first time and before I go I'm going to buy a new clutch just in case..........lol
Old Feb 7, 2006 | 10:01 AM
C6C6CH3vo's Avatar
I don't know why I shifted to 4th, I think I forgot not to, maybe I would of had like 7.999 but with a slower mph (interesting, the laws of physics and stuff). I was at about 7250 at the shift.
Thanks, My stock clutch has 28,000 miles with 7 passes down the strip and about 12 or so other slip launches. However the first month I had the car I needed to do an emergency get away and the clutch didn't grab - it just smoked all the way up to limiter - needless to say I didn't get out fast. Bottom line I'm happy with the stocker so far but dread the day I will need to replace.
Old Feb 7, 2006 | 10:36 AM
Warrtalon's Avatar
If you have never gone before, then you can't use that avatar.
Evoryder
102
Jan 2, 2018 05:30 AM
IMPORTIMAGE
Lancer Vendor Classifieds
421
Jul 13, 2016 07:01 AM
IMPORTIMAGE
Evo 'For Sale' Electronics / Lighting / Audio
40
Jul 13, 2016 06:49 AM
evovin
Jan 30, 2009 07:58 AM
Jrod@Buschur
100
Oct 9, 2008 03:54 PM
