My 1st pass w/ evo @ Drag strip
Originally Posted by FL_SilverEvo8
J DOG with them mods you got why is your best a 12.93 @ a high mile an hour than mine?
Maybe someone with more experience could shed some light on this. Also those runs with a 12.93 @ 105 were with a 1.75 60'. However, at another track that is faster for some reason I ran a 12.68 @ 107 with the exact same 60'. It's not in my sig because it's a track I've only been to once and I haven't been able to repeat it.
Also, no power shifting for me...heck I don't even know how to power shift. I'm also on the stock clutch at 32k on the odometer. I usually shift anywhere from 7300 rpms to 7500 rpms and this is on 92 octane running with 21.5 PSI tapering down to 17-18 PSI.
hey how do i get my mph up? where should i shift at? i think i was shifting at 7k. would that explain why my mph was so low in the 1/4? thanks everyone for the good comments.
Something is very wrong with your top-end. You freakin trapped 87mph in the 1/8th, which is crazy good, yet only gained 17mph in the back half. You were on track for a 12.5-12.6, but you lost a ton of power. With the same mods as you, I also hit 86-87mph in the 1/8th on pump gas, but then trap 108-109 in the 1/4. I only pick up 21-22mph, which isn't great either, but only picking up 17mph indicates some definite problems in 4th gear. You could be knocking, but that is not likely, since you have a dynoflash and your boost isn't cranked up too high. If you actually had your boost set to 23psi or something, then I'd point to that. Since you don't, then I'm not sure what the deal is.
Regardless, good job for your first time. It is very difficult to learn how to launch an AWD car, so cutting 1.8s is great. There's plenty of guys here who still can't hit a 1.8, and therefore still can't hit 12s.
I'm curious, though. How do you know how to powershift 1-2/2-3/3-4 when you've never drag-raced this car before? I don't even bother trying the 1-2 without a tuning device set for NLTS, but I do a semi-powershift (part-throttle) on the 2-3 and full powershift on the 3-4, because those are much easier, but I've done almost 100 drag passes in my Evo...
may be i should set up a cam in my car so you can see and then help me out. give me some poniters. then you would be able to hear the car and when i shift.but the only prob their is you prob wouldn't be able to see the tach. any idea's?
oh yeah someone posted up a 12 to 12.99. were he would put your name on the list. and what mph you did it at. their are a couple of people that did the same time some same mph and higher.
When I was looking at your slip your trap had me confused. All I have is a drop in panel filter, open rsr downpipe, dynoflash, and a jdm mr bov. I think you have basically the same but with an intake, mbc, and fuel pump.
Just so others know these are both the same track, same day, only minutes apart.
This is my slip:
R/T...... .816
60' ...... 1.882
330' .... 5.394
1/8 ......8.322
MPH ....82.36
1000 ..10.876
1/4 .....12.997
MPH ...105.79
Yours:
R/T......067
60'......1.844
330.....5.335
1/8......8.207
MPH....86.93
1000'...10.733
1/4......12.848
MPH......103.57
I really didn't get how you could be so much faster then me in the 1/8th and then I would trap more then 2 mph higher in the 1/4. I made up about 6 mph in the back half. I don't get it.
This is my slip:
R/T...... .816
60' ...... 1.882
330' .... 5.394
1/8 ......8.322
MPH ....82.36
1000 ..10.876
1/4 .....12.997
MPH ...105.79
Yours:
R/T......067
60'......1.844
330.....5.335
1/8......8.207
MPH....86.93
1000'...10.733
1/4......12.848
MPH......103.57
