My first time at the track
This is my first mannual car and also my first time at the track tell m what you guys think and if you guys think i can do better.
1st RUN
R/T .981
60 1.892
330 5.458
1/8 8.442
MPH 83.54
1000 11.019
1/4 13.174
MPH 105.09
2nd RUN
R/T 1.189
60 1.876
330 5.484
1/8 8.455
MPH 84.01
1000 11.014
1/4 13.152
MPH 105.95
Maybe next time i will break into the 12's
My mod are in my sig.
1st RUN
R/T .981
60 1.892
330 5.458
1/8 8.442
MPH 83.54
1000 11.019
1/4 13.174
MPH 105.09
2nd RUN
R/T 1.189
60 1.876
330 5.484
1/8 8.455
MPH 84.01
1000 11.014
1/4 13.152
MPH 105.95
you should already be in the 12's...... but atleast u know theres nothing wrong with your and its just driver, thats good..... just get out and do it more often.....then you'll be in the 12's maybe mid 12's soon
I'm filling in for Warrtalon because he is out of town - well, not really, I've only been to the strip twice myself, but nonetheless, let me give it a try.
Your 60' and shifting will definatly have to be improved to reach a 12.9x. Your only power mods are the MBC, TBE, and SAFC, so the car is making it's expected power with 105+mph traps.
With a custom tune and cams, 12.9 are possible with equivalent driving, but for the most part, not that bad for your first time.
Actually, a few things here:
1) Just need to learn to launch, and you'll have 12.9s with the same trap speeds. Your shifting isn't terrible, but it can improve. For comparison, I ran 13.17 @ 103.89 with a WORSE 60', so that means I was able to overcome a 2mph deficit and slower 60' just from faster shifting.
2) Your MPH does not reflect your dyno results. Almost exactly like you, my last dyno run was 294whp/269wtq with the same general mods and using an SAFC to tune. With that same tune, I went 12.52@108.5. I later replaced the SAFC with a base flash and went 12.26@110.0. With 298whp, you should be trapping closer to 109mph. 109mph is good enough for 12.4-12.5s.
3) I think with improved launches and improved shifting, you will not only improve your ET, but also your MPH, which will compound the effect on your improved ET.
U shoudl be in the 12's but its your first time, dont worry the next time u go to the track u will just get better, how was the rush going thru the 1/4 the first time with the EVO, my first time i ran a 13.5 and from then just kept going down everytime i go to the track 12.78 is the best time to date
dude the rush was sick i was taking reallly long breaths
i was thinking about my trap all night.
Also i was looking at some videos from last night when i ran and i noticed that half way down the track my car would go down a little dip i relly hate that tack its called moroso.
hey id say u did pretty good...i was at moroso last sunday for some import car thing and i saw about 3 evos with bolt ons doing 14.5s...14.7s..they did not kno how to drive...but then i saw the guys with more mods and that knew how to drive doing 11.8s...12.1s
So, you started off on the right foot, and now all you have to do is practice. You _WILL_ improve, and you _WILL_ hit 12s with no additional mods.
Not bad for a first time out, but 12s are def around the corner with some better driving. Try disconnecting the "launch control", there is a how to for that on the boards here. It will help you get better 60's.
