launches
Old Jan 4, 2006 | 07:43 PM
DragNRacing's Avatar
Tire pressure would be the easiest one keeping your current tires. Try starting around 25lbs and I wouldn't recommend going much lower than 23lbs unless you are running a drag radial with a soft/wrinkle sidewall.
Old Jan 5, 2006 | 07:42 AM
mitsutech005's Avatar
actually i have been getting the best hookup at 19 lbs
Old Jan 5, 2006 | 07:53 AM
Nesiop's Avatar
Ok.
When you say R-Compounds, that is referring to autocrossing or road racing tires that have a STIFF SIDEWALL to reduce rollover.
When you say Drag Radials, that is referring to drag racing tires with a SOFT SIDEWALL that allow the tires to flex.
You can go ahead and get R-compounds if you want, but they will not be good for drag racing and they will wear out in a few thousand miles.
Hmm, do R Compounds have to have a stiff sidewall? Toyo RA-1's I believe are R compounds and have soft sidewalls, thats why they can bubble easy and wear away very fast. People get maybe 10k miles on RA-1's.
Old Jan 5, 2006 | 07:56 AM
Nesiop's Avatar
Then why are you asking us these questions? You already know what you want and need, and you know so much about what tires are made of. I already told you that I hit consistent 1.9s and a best of 1.81 on my FWD Eclipse GS-T, but if you think the BFG "r compound" is better, then get those. Come back and show us your 1.7 60's on BFG R compounds. Why is this so difficult?
BFG R Compounds are Drag Radials, My friend uses them on his RS60T 97 GST Spyder.
Old Jan 5, 2006 | 07:56 PM
At that pressure you may loose some MPH on the top end due to the resistance of the tire but it may be overcome by the better 60'. At 23lbs I see almost zero difference between higher tire pressures but then again that is 23lbs on all four tires so I have more resistance. Anything less than 23lbs, I start to see a drop in MPH and the 60' does not improve enough to compensate.
Old Jan 5, 2006 | 08:16 PM
Warrtalon's Avatar
RA-1s are autocrossing tires. They have very stiff sidewalls. They wear away fast, because they have a 40 or 50 treadwear rating. I don't know anything about them bubbling easily or how that relates to sidewall stiffness.
